 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Windt H.J. - 4.07.2005 2:08)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Gaston - 3.07.2005 18:19
Hello,
I have written new example software for the RN-MOTOR, let me know what you think.
If everything works then maybe it could be posted on the roboter netz to help other people with the C-Control system.
Greetings,
H.J. Windt
'*                          WINDT SYSTEMS                                 *'
'*RN-MOTOR EXAMPLE VIA EMULATED I2C BUS v1.1 for CCIUM2.02 and CCIMainU1.1*'
'*                         2005/ H.J. WINDT                               *'
'*            With thanks to Gaston for testing the example!              *'
'This software for the C-Control I Unit M v2.02 and C-Control I Main U v1.1 will demonstrate using'
'the RN-MOTOR controller'
'Communication with the RN-MOTOR is via an emulated I2C bus.'
'Look under *** I/O PORTS *** for the I2C connections.'
'You may want to adjust some variables under ** INITIALIZATION SUBROUTINES ** to make the RN-MOTOR'
'work with your stepper motor(s)!!'
'**************** I/O PORTS ****************'
define sda port[4]
define scl port[5]
'**************** VARIABLES ****************'
define i2c_nack bit[1]
define i2c_last bit[2]
define i2c_nack_count byte[2]
define i2c_byte byte[3]
define i2c_out_bit bit[24]
define i2c_in_bit bit[17]
define loop byte[4]
define motor_selection byte[5]
define control byte[6]
define motor_direction byte[7]
define motor_speed byte[8]
define motor_continuous byte[9]
define motor_steps word[6]
define low_word word[7]
define high_word word[8]
'**************** CONSTANTS ****************'
'****************** SETUP ******************'
print"#ON_CONFIG#"; : put &b1000 : print"#OFF#"; '<<--TAKE THIS LINE AWAY FOR C-CONTROL MAIN UNIT V1.1!!'
gosub initialize_rn_motor
'***************** PROGRAM *****************'
#start
print"Enter motor selection/ 0 = left/ 1 = right/ 2 = both"
input motor_selection
print"Enter control/ 0 = stop motor(s)/ 1 = control motor(s)/ 2 = read motor steps taken"
input control
on control goto stop_motor, control_motor, read_motor_steps_taken
#stop_motor
gosub start_i2c
i2c_byte = &h56 : gosub write_byte_i2c
i2c_byte = 10 : gosub write_byte_i2c
i2c_byte = 3 : gosub write_byte_i2c
i2c_byte = motor_selection : gosub write_byte_i2c
i2c_byte = 255 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack_count > 18 then goto no_ack_from_i2c_device
if i2c_nack then goto stop_motor
goto start
#control_motor
print"Enter motor(s) direction/ 0 = left turn/ 1 = right turn"
input motor_direction
print"Enter motor(s) speed/ (0 to 255) 255 = slow"
input motor_speed
print"Turn motor(s) continuous?/ 0 = NO/ 1 = YES"
input motor_continuous
if motor_continuous = 1 then gosub rn_motor_control
if motor_continuous = 1 then goto start
print"Enter motor(s) steps to turn/ (0 to 32767)"
input motor_steps
goto start
#read_motor_steps_taken
if motor_selection > 1 then print "Cant read both motors at the same time!!"
if motor_selection > 1 then goto start
gosub start_i2c
i2c_byte = 13 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto pass_read
gosub start_i2c
i2c_byte = &h57 : gosub write_byte_i2c
gosub read_byte_i2c : low_word = i2c_byte
gosub read_byte_i2c : low_word = i2c_byte * 256 + low_word
gosub read_byte_i2c : high_word = i2c_byte
gosub read_last_byte_i2c : high_word = i2c_byte * 256 + high_word
gosub stop_i2c
#pass_read
if i2c_nack then goto read_motor_steps_taken
print"HIGH word = ";high_word;" Low word = ";low_word
goto start
end
'*************** SUBROUTINES ***************'
#rn_motor_control
#set_motor_direction
gosub start_i2c
i2c_byte = 4 : gosub write_byte_i2c
i2c_byte = motor_direction : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto set_motor_direction
#set_motor_speed
gosub start_i2c
i2c_byte = 8 : gosub write_byte_i2c
i2c_byte = motor_speed : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto set_motor_speed
if motor_continuous = 1 then goto turn_motor_continuous
#turn_motor_number_of_steps
gosub start_i2c
i2c_byte = 5 : gosub write_byte_i2c
i2c_byte = motor_steps mod 256 : gosub write_byte_i2c
i2c_byte = motor_steps / 256 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto turn_motor_number_of_steps
return
#turn_motor_continuous
gosub start_i2c
i2c_byte = 6 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto turn_motor_continuous
return
#start_i2c
sda = 0 : scl = 0
return
#stop_i2c
sda = 0 : deact scl : deact sda
return
#write_byte_i2c
for loop = 1 to 8
sda = i2c_out_bit
deact scl
#write_byte_i2c_clock_stretch
if not scl then goto write_byte_i2c_clock_stretch
scl = 0
i2c_byte = i2c_byte shl 1
next
deact sda
deact scl
#write_byte_i2c_ack_clock_stretch
if not scl then goto write_byte_i2c_ack_clock_stretch
i2c_nack = sda
scl = 0
if i2c_nack then goto i2c_error
i2c_nack_count = 0
return
#i2c_error
i2c_nack_count = i2c_nack_count + 1
goto stop_i2c
#read_byte_i2c
i2c_last = 0
#get_i2c_byte
deact sda
for loop = 1 to 8
deact scl
#read_byte_i2c_clock_stretch
if not scl then goto read_byte_i2c_clock_stretch
i2c_in_bit = sda
scl = 0
if loop < 8 then i2c_byte = i2c_byte shl 1
next
if i2c_last then deact sda else sda = 0
deact scl
#read_byte_i2c_ack_clock_stretch
if not scl then goto read_byte_i2c_ack_clock_stretch
scl = 0
return
#read_last_byte_i2c
i2c_last = 1
goto get_i2c_byte
'******* INITIALIZATION SUBROUTINES ********'
#initialize_rn_motor
#set_motor_amps
gosub start_i2c
i2c_byte = 1 : gosub write_byte_i2c
i2c_byte = 2 : gosub write_byte_i2c
i2c_byte = 190 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto set_motor_amps
#set_mode
gosub start_i2c
i2c_byte = 14 : gosub write_byte_i2c
i2c_byte = 0 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto set_mode
#switch_motors_on
gosub start_i2c
gosub stop_i2c
if i2c_nack then goto switch_motors_on
#show_configuration
gosub start_i2c
i2c_byte = 11 : gosub write_byte_i2c
gosub stop_i2c
if i2c_nack then goto show_configuration
return
'****************** DATA *******************'
'************* ERROR MESSAGES **************'
#no_ack_from_i2c_device
print"**************************"
print"* No ACK from I2C device *"
pause 50
> Hello,
> the display is "202"
> I understand what you mean. Is it not possible to read out the corresponding 4 bytes and to
> handle this problem in a seperate routine?
> Greetings,
> Gaston
> > Hello again,
> > I'm glad to hear that the RN-MOTOR controller is now working!!
> > There is a problem with code 13:
> > The c-control I v1.1 and v2.0x will only handle 16 bit variables but the read out of  number of steps is a 32 bit variable ( 0 to 4294967295), this will not work on the c-control I system.
> > Also, the c-control I 16 bit variables are signed integers, this means that the variables are 0 to 32767 and -32768 to -1 and not 0 to 65535.
> > I have an idea how you can use the RN-MOTOR in a more controlled fashion, without the need for code 13, but I first need to know which version of the c-control you are using.
> > Load and run the program below and let me know what is displayed.
> > Greetings,
> > H.J. Windt
> > define version byte[64]
> > put 0
> > print version
> > > I have already the solution for code 11. It is very simple because the data output is via RS232 of the RN-Motor board only. But code 13 is a problem for me....
> > > Greetings
> > > Gaston
Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 11:56)
    Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 13:28)
        Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 13:59)
            Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 14:39)
                Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 14:48)
                    Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 15:00)
                       Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 15:12)
                          Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 18:24)
                             Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 10:59)
                                Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 14:10)
                                   Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 17:48)
                                     Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 19:00)
                                       Re: RN-Motor an I2C-Bus (von Gaston - 7.07.2005 16:00)
