 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Gaston - 5.07.2005 10:59)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Windt H.J. - 4.07.2005 18:24
Gaston nutzt:  CC1-Station V2.0
Hello again,
I have a RN-Motor ST. Changing all the “i2c_byte = 255” into “i2c_byte = 0” has no effect.
I have not tried pull up resistors until now. I think, if writing is possible there is no reason why reading makes problems.
I have searched the net and found a thread on this problem, but it is in german only:
http://www.roboternetz.de/phpBB2/viewtopic.php?t=10104
There you can find another solution, but it is written in Basic++ and I have no experience with it...
If you can't find it please inform me and I will send you the programm.
Greetings
Gaston
> Hello,
> IÂ’m at a complete loss why the steps canÂ’t be read out.
> I have had no problems with any I2C device and my subroutines and it almost seems to me to be a hardware/ software problem of the RN-MOTOR ST but you could first try using different pull up resistors on the scl and sda line to see if this helps.
> You could also try changing all the “i2c_byte = 255” into “i2c_byte = 0”.
> Could it be that you have a RN-MOTOR GT instead of the ST version??
> Try asking on a forum if anybody has had problems reading out the steps of the motor controller.
> Let me know how it works out.
> Greetings,
> H.J. Windt
Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 14:10)
    Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 17:48)
        Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 19:00)
            Re: RN-Motor an I2C-Bus (von Gaston - 7.07.2005 16:00)
