 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Gaston - 5.07.2005 17:48)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Windt H.J. - 5.07.2005 14:10
Gaston nutzt:  CC1-M-Unit V1.2/2.0
Hello again,
That was the problem! Now everything works fine.
I have implemented the changes to my programm and reading out the number of steps is no longer a problem.
Thank you very much for your great help!!!
Gaston
> Hello,
> I have already looked into this forum to see if anybody had troubles reading the steps taken but did not find anything.
> It looks like that basic++ is a mix of basic and c++, I looked at the code but I donÂ’t like what I see, the code does not take I2C clock stretching into consideration, this is really important if you are using micro controller based slaves, my code does.
> Also, to make an i2c port go HIGH you do not sda = 1 or sda = on, I think this is not good, you must deact sda, the pullup resistor will do the rest.
> I want to try something else, replace the code with the code below, and let me know if this works.
> Greetings,
> H.J. Windt
> #read_motor_steps_taken
> if motor_selection > 1 then print "Cant read both motors at the same time!!"
> if motor_selection > 1 then goto start
> gosub start_i2c
> i2c_byte = &h56 : gosub write_byte_i2c
> i2c_byte = 10 : gosub write_byte_i2c
> i2c_byte = 13 : gosub write_byte_i2c
> i2c_byte = motor_selection : gosub write_byte_i2c
> gosub stop_i2c
> if i2c_nack then goto pass_read
> gosub start_i2c
> i2c_byte = &h57 : gosub write_byte_i2c
> gosub read_byte_i2c : low_word = i2c_byte
> gosub read_byte_i2c : low_word = i2c_byte * 256 + low_word
> gosub read_byte_i2c : high_word = i2c_byte
> gosub read_last_byte_i2c : high_word = i2c_byte * 256 + high_word
> gosub stop_i2c
> #pass_read
> if i2c_nack_count > 18 then goto no_ack_from_i2c_device
> if i2c_nack then goto read_motor_steps_taken
> print"HIGH word = ";high_word;" Low word = ";low_word
> goto start
Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 19:00)
    Re: RN-Motor an I2C-Bus (von Gaston - 7.07.2005 16:00)
