 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Windt H.J. - 4.07.2005 18:24)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Gaston - 4.07.2005 15:12
Hello,
IÂ’m at a complete loss why the steps canÂ’t be read out.
I have had no problems with any I2C device and my subroutines and it almost seems to me to be a hardware/ software problem of the RN-MOTOR ST but you could first try using different pull up resistors on the scl and sda line to see if this helps.
You could also try changing all the “i2c_byte = 255” into “i2c_byte = 0”.
Could it be that you have a RN-MOTOR GT instead of the ST version??
Try asking on a forum if anybody has had problems reading out the steps of the motor controller.
Let me know how it works out.
Greetings,
H.J. Windt
Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 10:59)
    Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 14:10)
        Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 17:48)
            Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 19:00)
                Re: RN-Motor an I2C-Bus (von Gaston - 7.07.2005 16:00)
