 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Gaston - 3.07.2005 18:19)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Windt H.J. - 3.07.2005 17:31
Hello,
the display is "202"
I understand what you mean. Is it not possible to read out the corresponding 4 bytes and to
handle this problem in a seperate routine?
Greetings,
Gaston
> Hello again,
> I'm glad to hear that the RN-MOTOR controller is now working!!
> There is a problem with code 13:
> The c-control I v1.1 and v2.0x will only handle 16 bit variables but the read out of  number of steps is a 32 bit variable ( 0 to 4294967295), this will not work on the c-control I system.
> Also, the c-control I 16 bit variables are signed integers, this means that the variables are 0 to 32767 and -32768 to -1 and not 0 to 65535.
> I have an idea how you can use the RN-MOTOR in a more controlled fashion, without the need for code 13, but I first need to know which version of the c-control you are using.
> Load and run the program below and let me know what is displayed.
> Greetings,
> H.J. Windt
> define version byte[64]
> put 0
> print version
> > I have already the solution for code 11. It is very simple because the data output is via RS232 of the RN-Motor board only. But code 13 is a problem for me....
> > Greetings
> > Gaston
Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 2:08)
    Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 11:56)
        Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 13:28)
            Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 13:59)
                Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 14:39)
                    Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 14:48)
                       Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 15:00)
                          Re: RN-Motor an I2C-Bus (von Gaston - 4.07.2005 15:12)
                             Re: RN-Motor an I2C-Bus (von Windt H.J. - 4.07.2005 18:24)
                                Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 10:59)
                                   Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 14:10)
                                     Re: RN-Motor an I2C-Bus (von Gaston - 5.07.2005 17:48)
                                       Re: RN-Motor an I2C-Bus (von Windt H.J. - 5.07.2005 19:00)
                                         Re: RN-Motor an I2C-Bus (von Gaston - 7.07.2005 16:00)
