 Voltcraft Charge Manager 2020 - Monitor Mode access Kategorie: Verschiedenes (von TeK - 14.01.2006 0:33)
Sorry for writing in English but my German is really bad.
I've recently bought a battery charger from Conrad (Voltcraft Charge Manager 2020).
Overall it is doing a good job but it has some limitations that I would like to bypass by modifying its
firmware.
I have been able to obtain the schematics for this charger and it is using a MC68HC908GT16 chip.
If I'm not mistaken, this is the same chip as the one used for C-Control I M-Unit 2.0.
On the schematics, there are pins labeled "Monitor Mode" and "Monitor Data" (as well as a few
others). I've read part of the chip's datasheet and the Monitor Mode is apparently the way to access
the flash (READ / WRITE) of the MC68HC908GT16.
I suspect that this charger is *somehow* compatible with the C-Control I M-Unit 2.0 tools. Maybe
these tools can be used to read and write the flash of the charger.
Would anyone happen to know how I could interface this charger with a PC (RS-232)? Are there
ready-made C-Control interfaces to do the job? Is there software as well?
Thanks
TeK
Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von DIE HARD - 14.01.2006 13:57)
    Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von Friedrich - 14.01.2006 19:18)
        Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von DIE HARD - 14.01.2006 22:30)
            Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von Friedrich - 15.01.2006 0:27)
    Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 14.01.2006 16:10)
        Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von DIE HARD - 14.01.2006 22:22)
            Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 14.01.2006 23:24)
                Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von Dietmar - 15.01.2006 14:51)
                    Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 16.01.2006 0:20)
                       Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von Dietmar - 16.01.2006 20:36)
                          Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 16.01.2006 21:59)
