 Re: Voltcraft Charge Manager 2020 - Monitor Mode access Kategorie: Verschiedenes (von Dietmar, Homepage - 15.01.2006 14:51)
 Als Antwort auf Re: Voltcraft Charge Manager 2020 - Monitor Mode access von TeK - 14.01.2006 23:24
Dietmar nutzt:  CC1-M-Unit V1.1, Advanced CC1-Unit, Open-Micro, Open-Mini, Open-Mini M-Unit, Open-Mini Station
Hello TeK
> The datasheet is not perfectly clear but it seems that without the security bytes it is still possible to read and write to RAM. From there it should be easy to get the job done (i.e. dump the flash) with the RUN command ($28).
I didn't tried it yet with a GT16, but only with the QT4 and the QY4. If any wrong security byte have been transmitted, the controller is switched into a mode, in which the Flash works like an not implemented memory section. It seems the Flash is simply switched off. Maybe the difference make if the COP Control Register (COPCTL) on $ffff is first read or first written after reset. AFAIK the only way to find the values of the eight bytes is to guess them or to use brute force. The latter might take very long.
> It would help if I could get the Monitor ROM of the chip for analysis.
The contents of the MONITOR ROM isn't a secret. In the past I dumped and disassembled the two ROM areas of an empty GT16.
> But apparently in Monitor Mode, command $49 allows to write one byte at a time (I guess that either the Monitor ROM or the Flash ROM take care of writing a full row).
At least in the MON08 of the QT4 and QY4 this command can write only to RAM and to registers. This command corresponds to a "STA ,X". But various registers must be set to delete and write to Flash. And it's time critical. Alternatively one can use the routines in the first ROM (FLASH PROGRAMMING ROUTINES ROM, address $1b50 to $1e1f).
Here's the ROM listing. The Reset Vector in Monitor Mode is at $fefe and $feff. And the SWI Vector is at $fefc and $fefd. (See Table 15-2 in manual.) After reset execution starts at $ff00.
; =    Project   : ROM-Listing of MONITOR ROM of an empty 68HC908GT16       =
; =    Mnemonic  : AS05 for M6805 [1.40] from Frank A. Vorstenbosch         =
; =    made by   : Dietmar Harlos ADPC                                      =
fe20 : f7     sta ,x              ; store accumulator at address in hx
fe21 : f6     lda ,x              ; load accu with value at address in hx
fe22 : 000002 brset #0,$00,$fe27  ; branch to $fe27 if bit #0 at $00 is set
fe25 : bc41   jmp $41             ; unconditional jump to address $41
fe27 : 83     swi                 ; software interrupt (addr. at $fffc:$fffd)
fe28 : 1104   bclr #0,$04         ; clear bit #0 at memory address $04
fe2a : 8b     pushh               ; push h-register onto stack
fe2b : 1100   bclr #0,$00         ; clear bit #0 at memory address $00
fe2d : ad52   bsr $fe81           ; branch to subroutine at address $fe81
fe2f : ad66   bsr $fe97           ; branch to subroutine at address $fe97
fe31 : 87     pusha               ; push accu onto stack
fe32 : 48     lsla                ; shift left accumulator
fe33 : 2a07   bpl $fe3c           ; branch if plus (N bit is clear)
fe35 : ad60   bsr $fe97           ; branch to subroutine at address $fe97
fe37 : 87     pusha               ; push accu onto stack
fe38 : 8a     poph                ; pop (pull) h-register from stack
fe39 : ad5c   bsr $fe97           ; branch to subroutine at address $fe97
fe3b : 97     tax                 ; transfer accumulator to x-register
fe3c : 86     popa                ; pop (pull) accu from stack
fe3d : 84     tap                 ; transfer accu to processor status byte
fe3e : 251c   blo $fe5c           ; branch if reg. is lower (C is set)
fe40 : ad33   bsr $fe75           ; branch to subroutine at address $fe75
fe42 : 84     tap                 ; transfer accu to processor status byte
fe43 : 280b   bhcc $fe50          ; branch if half carry bit clear (H clear)
fe45 : e601   lda $01,x           ; load accu with value at addr. $01+hx
fe47 : ad61   bsr $feaa           ; branch to subroutine at address $feaa
fe49 : af02   aix #$02            ; add signed value to index register (hx)
fe4b : f6     lda ,x              ; load accu with value at address in hx
fe4c : ad5c   bsr $feaa           ; branch to subroutine at address $feaa
fe4e : 20df   bra $fe2f           ; branch always to $fe2f
fe50 : 27f9   beq $fe4b           ; branch if equal (Z is set)
fe52 : 2b19   bmi $fe6d           ; branch if minus (N bit is set)
fe54 : a828   eor #$28            ; XOR accumulator with value #$28
fe56 : 2702   beq $fe5a           ; branch if equal (Z is set)
fe58 : ad27   bsr $fe81           ; branch to subroutine at address $fe81
fe5a : 8a     poph                ; pop (pull) h-register from stack
fe5b : 80     rti                 ; return from interrupt
fe5c : 2907   bhcs $fe65          ; branch if half carry bit set (H is set)
fe5e : ad37   bsr $fe97           ; branch to subroutine at address $fe97
fe60 : ad13   bsr $fe75           ; branch to subroutine at address $fe75
fe62 : f7     sta ,x              ; store accumulator at address in hx
fe63 : 20ca   bra $fe2f           ; branch always to $fe2f
fe65 : ad30   bsr $fe97           ; branch to subroutine at address $fe97
fe67 : ad0c   bsr $fe75           ; branch to subroutine at address $fe75
fe69 : af01   aix #$01            ; add signed value to index register (hx)
fe6b : 20f5   bra $fe62           ; branch always to $fe62
fe6d : 95     tsx                 ; transfer stack pointer (sp+1) to hx
fe6e : 8b     pushh               ; push h-register onto stack
fe6f : 86     popa                ; pop (pull) accu from stack
fe70 : ad38   bsr $feaa           ; branch to subroutine at address $feaa
fe72 : 9f     txa                 ; transfer x-register to accumulator
fe73 : 20d7   bra $fe4c           ; branch always to $fe4c
fe75 : 87     pusha               ; push accu onto stack
fe76 : a60b   lda #$0b            ; load accumulator with value #$0b
fe78 : ad54   bsr $fece           ; branch to subroutine at address $fece
fe7a : 2404   bhs $fe80           ; branch if reg. is higher or same (C clear)
fe7c : 4bfa   dbnza $fe78         ; decrement accu and branch if not zero
fe7e : 86     popa                ; pop (pull) accu from stack
fe7f : 81     rts                 ; return from subroutine
fe80 : 86     popa                ; pop (pull) accu from stack
fe81 : 0100fd brclr #0,$00,$fe81  ; branch to $fe81 if bit #0 at $00 is clear
fe84 : aea9   ldx #$a9            ; load x-register with value #$a9
fe86 : 5bfe   dbnzx $fe86         ; decrement x-reg. and branch if not zero
fe88 : 1004   bset #0,$04         ; set bit #0 at memory address $04
fe8a : 2000   bra $fe8c           ; branch always to $fe8c
fe8c : 5bfa   dbnzx $fe88         ; decrement x-reg. and branch if not zero
fe8e : 1104   bclr #0,$04         ; clear bit #0 at memory address $04
fe90 : a702   ais #$02            ; add signed value to stack pointer (sp)
fe92 : c6ffff lda $ffff           ; load accumulator with value at $ffff
fe95 : 2098   bra $fe2f           ; branch always to $fe2f
fe97 : 0000fd brset #0,$00,$fe97  ; branch to $fe97 if bit #0 at $00 is set
fe9a : ad32   bsr $fece           ; branch to subroutine at address $fece
fe9c : 25f9   blo $fe97           ; branch if reg. is lower (C is set)
fe9e : a680   lda #$80            ; load accumulator with value #$80
fea0 : ad2c   bsr $fece           ; branch to subroutine at address $fece
fea2 : 46     rora                ; rotate accumulator right through carry
fea3 : 9d     nop                 ; no operation (wait for one cycle)
fea4 : 24fa   bhs $fea0           ; branch if reg. is higher or same (C clear)
fea6 : ad26   bsr $fece           ; branch to subroutine at address $fece
fea8 : 24d7   bhs $fe81           ; branch if reg. is higher or same (C clear)
feaa : 89     pushx               ; push x-register onto stack
feab : 87     pusha               ; push accu onto stack
feac : a60a   lda #$0a            ; load accumulator with value #$0a
feae : 0100fd brclr #0,$00,$feae  ; branch to $feae if bit #0 at $00 is clear
feb1 : aea9   ldx #$a9            ; load x-register with value #$a9
feb3 : 5bfe   dbnzx $feb3         ; decrement x-reg. and branch if not zero
feb5 : 99     sec                 ; set carry bit
feb6 : 2009   bra $fec1           ; branch always to $fec1
feb8 : 9e     db $9e              ; replace ,x with ,sp in next instruction
feb9 : 6601   ror $01,x           ; rotate right through carry at $01+hx
febb : 2404   bhs $fec1           ; branch if reg. is higher or same (C clear)
febd : 1104   bclr #0,$04         ; clear bit #0 at memory address $04
febf : 2004   bra $fec5           ; branch always to $fec5
fec1 : 1004   bset #0,$04         ; set bit #0 at memory address $04
fec3 : 2000   bra $fec5           ; branch always to $fec5
fec5 : ae4f   ldx #$4f            ; load x-register with value #$4f
fec7 : 5bfe   dbnzx $fec7         ; decrement x-reg. and branch if not zero
fec9 : 4bed   dbnza $feb8         ; decrement accu and branch if not zero
fecb : 86     popa                ; pop (pull) accu from stack
fecc : 88     popx                ; pop (pull) x-register from stack
fecd : 81     rts                 ; return from subroutine
fece : 89     pushx               ; push x-register onto stack
fecf : 87     pusha               ; push accu onto stack
fed0 : a610   lda #$10            ; load accumulator with value #$10
fed2 : ae17   ldx #$17            ; load x-register with value #$17
fed4 : 010000 brclr #0,$00,$fed7  ; branch to $fed7 if bit #0 at $00 is clear
fed7 : a200   sbc #$00            ; subtract with carry value #$00 from accu
fed9 : 5bf9   dbnzx $fed4         ; decrement x-reg. and branch if not zero
fedb : 49     rola                ; rotate accumulator left through carry
fedc : 86     popa                ; pop (pull) accu from stack
fedd : 88     popx                ; pop (pull) x-register from stack
fede : 81     rts                 ; return from subroutine
fedf :  ff ff ff ff ff ff ff ff  --  ff ff ff ff ff ff ff ff
feef :  ff ff ff ff ff ff ff ff  --  ff 9d 9d 9d 15 fe 28 ff            Ã˜Ã˜Ã˜._(
feff :  00                       --                            .
ff00 : 2f0f   bih $ff11           ; branch if external IRQ pin is high
ff02 : 6e2037 mov #$20,$37        ; store value #$20 to address $37
ff05 : c6ff80 lda $ff80           ; load accumulator with value at $ff80
ff08 : 43     coma                ; inverse accumulator (one's complement)
ff09 : 2703   beq $ff0e           ; branch if equal (Z is set)
ff0b : 43     coma                ; inverse accumulator (one's complement)
ff0c : b738   sta $38             ; store accumulator at address $38
ff0e : 0536fd brclr #2,$36,$ff0e  ; branch to $ff0e if bit #2 at $36 is clear
ff11 : a7fa   ais #$fa            ; add signed value to stack pointer (sp)
ff13 : 1100   bclr #0,$00         ; clear bit #0 at memory address $00
ff15 : 6eff40 mov #$ff,$40        ; store value #$ff to address $40
ff18 : 45fff6 ldhx #$fff6         ; load index register (hx) with value
ff1b : 010002 brclr #0,$00,$ff20  ; branch to $ff20 if bit #0 at $00 is clear
ff1e : 1f40   bclr #7,$40         ; clear bit #7 at memory address $40
ff20 : 51fe1a cbeqx #$fe,$ff3d    ; compare x-reg with value & branch if equal
ff23 : b600   lda $00             ; load accu with value at address $00
ff25 : 0e4003 brset #7,$40,$ff2b  ; branch to $ff2b if bit #7 at $40 is set
ff28 : cdfe97 jsr $fe97           ; jump to subroutine at address $fe97
ff2b : 9d     nop                 ; no operation (wait for one cycle)
ff2c : 71f2   cbeq ,x+,$ff20      ; cmp. accu with memory at hx, inc hx & beq
ff2e : 51fe12 cbeqx #$fe,$ff43    ; compare x-reg with value & branch if equal
ff31 : b600   lda $00             ; load accu with value at address $00
ff33 : 0e4003 brset #7,$40,$ff39  ; branch to $ff39 if bit #7 at $40 is set
ff36 : cdfe97 jsr $fe97           ; jump to subroutine at address $fe97
ff39 : af01   aix #$01            ; add signed value to index register (hx)
ff3b : 20f1   bra $ff2e           ; branch always to $ff2e
ff3d : aeff   ldx #$ff            ; load x-register with value #$ff
ff3f : 9c     rsp                 ; reset stack pointer (sp=$00ff)
ff40 : ccfe20 jmp $fe20           ; unconditional jump to address $fe20
ff43 : 1d40   bclr #6,$40         ; clear bit #6 at memory address $40
ff45 : aeff   ldx #$ff            ; load x-register with value #$ff
ff47 : 9c     rsp                 ; reset stack pointer (sp=$00ff)
ff48 : ccfe21 jmp $fe21           ; unconditional jump to address $fe21
ff4b :  ff ff ff ff ff           --
Let me know if you manage to patch the 2020.
Greetings
Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 16.01.2006 0:20)
    Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von Dietmar - 16.01.2006 20:36)
        Re: Voltcraft Charge Manager 2020 - Monitor Mode access (von TeK - 16.01.2006 21:59)
