> Hallo > Even thougt the CM 2020 has the same CPU it has nothing to do with the C-Control. > The CM 2020 operating system is completely written in assembly language. > ciao..... Thanks for your reply. Assembler doesn't scare me off really. All I need to do is patch a couple of bytes in the flash. Would you happen to have a dump? My first problem is that I'm not a hardware genius and I don't know how to connect the monitor mode to a PC, although there are schematics to do that in the MC68HC908GT16 datasheet. It doesn't seem too complicated. I can probably ask a friend of mine for some help but I was wondering if there was an interface that I could buy. My second problem is that to enter Monitor Mode on this micro-controller, you need to give an 8 bytes key. I was thinking that maybe there is a "standard" C-Control key. Otherwise I may have to go the hard way. BTW, could anyone provide me with the 304 bytes of Monitor ROM located at [$FE20-$FF4F]? Thanks TeK |
