Hello, sorry for the English. I see that you are using the Enable Latch (pin 11) to open the ports but you should be using the Output Control (pin 1). http://www.ancr.org/datasheet/logic/74HC573.pdf Connect all the 74HC573Â’s pin 11 (Enable Latch) to +5V. Connect port 14 to your #1 74HC573 pin 1 (Output Control). Connect port 15 to your #2 74HC573 pin 1 (Output Control) Connect port 16 to your #3 74HC573 pin 1 (Output Control) Try the program below and let me know how it works out. ;) Greetings, H.J. Windt define Bus byteport[1] define Output_control1 port[14] define Output_control2 port[15] define Output_control3 port[16] define Adresse byte define Daten byte ' --- Programmoperationen ------------- Output_control1 = 1 : Output_control2 = 1 : Output_control3 = 1 'Puts all 74hc573 in high impedance state' #Loop gosub In1 print "Adresse 1: ", Daten gosub In2 print "Adresse 2: ", Daten gosub In3 print "Adresse 3: ", Daten pause 20 goto Loop 'Endlosschleife #In1 Output_control1 = 0 'Open #1 74hc573 output' Daten = Bus 'Read data' Output_control1 = 1 'Puts 74hc573 #1 in high impedance state' return #In2 Output_control2 = 0 'Open #2 74hc573 output' Daten = Bus 'Read data' Output_control2 = 1 'Puts 74hc573 #2 in high impedance state' return #In3 Output_control3 = 0 'Open #3 74hc573 output' Daten = Bus 'Read data' Output_control3 = 1 'Puts 74hc573 #3 in high impedance state' return end |
