 WAIT……There is one more thing! Kategorie: Programmierung Basic (von H.J.W. - 22.12.2006 13:39)
 Als Antwort auf Re: kommazahlen von H.J.W. - 21.12.2006 22:15
I forgot to mention something:
The Temperatur/10 must be changed to abs(temperature/10) otherwise, for example, -1.0 (-10) will be displayed as --1,0.
If Temperatur < 0 then print”-”
Print abs(Temperatur/10);”,”;abs(Temperatur)mod 10
Greetings,
H.J.W.
> ManfredW is absolutely correct,
> The If Temperatur < 0 then print”-” must be placed in front of your code otherwise temperatures from -0,1 (-1) to -0,9 (-9) will not be displayed with a “-” but be display as 0,1 to 0,9.
> Example:
> Temperatur = -3 ‘-0,3’
> Print Temperatur/10;”,”;abs(Temperatur)mod 10
> Temperatur/10 is 0
> Abs(Temperatur)mod 10 is 3
> So with your code the temperature of -0,3 will be displayed as 0,3.
> Greetings,
> H.J.W.
Re: WAIT……There is one more thing! (von Achim - 22.12.2006 23:48)
