 Re: WAIT……There is one more thing! Kategorie: Programmierung Basic (von Achim - 22.12.2006 23:48)
 Als Antwort auf WAIT……There is one more thing! von H.J.W. - 22.12.2006 13:39
Details, details ...
That all should be left for the student as an exercise, anyway. ;-)
Bye
 Achim
> I forgot to mention something:
> The Temperatur/10 must be changed to abs(temperature/10) otherwise, for example, -1.0 (-10) will be displayed as --1,0.
> If Temperatur < 0 then print”-”
> Print abs(Temperatur/10);”,”;abs(Temperatur)mod 10
> Greetings,
> H.J.W.
> > ManfredW is absolutely correct,
> > The If Temperatur < 0 then print”-” must be placed in front of your code otherwise temperatures from -0,1 (-1) to -0,9 (-9) will not be displayed with a “-” but be display as 0,1 to 0,9.
> > Example:
> > Temperatur = -3 ‘-0,3’
> > Print Temperatur/10;”,”;abs(Temperatur)mod 10
> > Temperatur/10 is 0
> > Abs(Temperatur)mod 10 is 3
> > So with your code the temperature of -0,3 will be displayed as 0,3.
> > Greetings,
> > H.J.W.
