ManfredW is absolutely correct, The If Temperatur < 0 then print”-” must be placed in front of your code otherwise temperatures from -0,1 (-1) to -0,9 (-9) will not be displayed with a “-” but be display as 0,1 to 0,9. Example: Temperatur = -3 ‘-0,3’ Print Temperatur/10;”,”;abs(Temperatur)mod 10 Temperatur/10 is 0 Abs(Temperatur)mod 10 is 3 So with your code the temperature of -0,3 will be displayed as 0,3. Greetings, H.J.W. |
