Hello Hans, #OpStart > Minute = 0 > > > #Start > FOR I = 1 to 200 > IF MINUTE>4 THEN GOTO GeenOntvangst Here is the first problem. If minute is higher then 4 it jumps to routine GeenOntvangst When GeenOntvangst is done then it jumps to Opstart but.... what about the For I = 1 to 200 loop?? Your software does not allow the For I loop to complete, "NEXT", and this is where the problems begin. > IF NOT RXD THEN GOTO Verder > GET Var1 > IF Var1=68 THEN GOTO Ontvang '83 is "S" van Start Next problem, is the same problem as above. > #Verder > NEXT > GOTO Start As i wrote before, you must be careful when using "for" "next" "goto" and "gosub". I'm not sure why you are using the FOR I = 1 to 200 but i think your software would work without it. Greetings, H.J.W. |
