Hello Hans, >#GeenOntvangst >E=ON >print"#ON_LCD#"; >print"#INIT#"; You don't need to initialize the LCD everytime you want to print, this only needs to be done once at the begining of your software. >print"#L101#"; >print "****** Geen ontvangst ******"; >print"#L201#"; >print"Storing Kijk of de afzender goed aangeslo"; >E=OFF >print"#ON_LCD#"; This line in not necessary. >print"#INIT#"; This line in not necessary. >print"#L101#"; should this not be print"#L121#"; ? >print "ten is. Spanning aangesloten "; >print"#L201#"; Should this not be print"#L221#"; ? >print"of draadbreuk in de data kabel "; You forgot a PRINT"#OFF#"; here! This could be the remaining problem. >GOTO Opstart >#Display 'Display 4x40 >aanTal=AanTal+1 >E=ON >print"#ON_LCD#"; >print"#INIT#"; This line is not necessary >print"#CLR"; This should be print"#CLR#"; >print"#L101#"; >PRINT "Getal1=";Var1; >print"#L201#"; >PRINT "Getal2=";Var2; >print"#L121#"; >PRINT "Getal3=";Var3; >print"#L221#"; 'Regel 4, POSITON 1 >PRINT "Getal4=";Var4; >E=OFF >print"#INIT#"; This line is not necessary For testing, put a pause here, otherwise you will not be able to read the data. >print"#CLR"; This line should be print"#CLR#"; >print"#L101#"; >PRINT "Getal5=";Var5; >print"#L201#"; >PRINT "Getal6=";Var6; >print"#L221#"; >PRINT Aantal; >print"#OFF#"; HEY! you remembered this! ;) >pause 150 >GOTO Opstart Greetings, H.J.W. |
