Hallo I have 2x M-units2.0 1 Sender en 1 reciever serial RS485 The program works good only +/- one out of ten is goiing wrong then there is coming in wrong information the number "68" (start code) is coming on Varbyte1 or Varbyte2 on wich the other variable are moving up why is this program so unstable or with other words, how do I get this program stable Hans '********TEST SENDER************ 'poort DEFINE Led PORT[1] 'VAR DEFINE VarByte2 BYTE[3] 'Bytes op een rij 1 t/m 48 bits DEFINE VarByte1 BYTE[4] DEFINE VarByte4 BYTE[5] DEFINE VarByte3 BYTE[6] DEFINE VarByte6 BYTE[7] DEFINE VarByte5 BYTE[8] DEFINE Temp WORD[5] put 0 led=OFF VarByte6=0 #Start TOG Led VarByte1=10 VarByte2=20 VarByte3=30 VarByte4=40 VarByte5=255 VarByte6=VarByte6+1 PUT 68 'is the start code PUT VarByte1 PUT VarByte2 PUT VarByte3 PUT VarByte4 PUT VarByte5 PUT VarByte6 pause 50 GOTO Start '*******Test Resiever********** define lED port[1] DEFINE E PORT[16] DEFINE Var1 BYTE[1] DEFINE Var2 BYTE[2] DEFINE Var3 BYTE[3] DEFINE Var4 BYTE[4] DEFINE Var5 BYTE[5] DEFINE Var6 BYTE[6] DEFINE VAR7 BYTE[7] DEFINE I BYTE[8] DEFINE AanTal WORD[5] AanTal=0 PRINT"#ON_LCD#";"#INIT#";"#CLR#";"#OFF#"; PUT 0 #OpStart Minute = 0 #Start FOR I = 1 to 200 IF MINUTE>4 THEN GOTO GeenOntvangst IF NOT RXD THEN GOTO Verder GET Var1 IF Var1=68 THEN GOTO Ontvang '83 is "S" van Start #Verder NEXT GOTO Start #Ontvang GET Var1 'Óntvangen van de 48 BITS in 6 Byte's GET Var2 GET Var3 GET Var4 GET Var5 GET Var6 GET Var7 'IF Var7<>69 THEN GOTO Start 'Laatste Var moet een "E" Zijn van End #Display 'Display 4x40 aanTal=AanTal+1 E=ON print"#ON_LCD#"; print"#INIT#"; print"#CLR"; print"#L101#"; PRINT "Getal1=";Var1; print"#L201#"; PRINT "Getal2=";Var2; print"#L121#"; PRINT "Getal3=";Var3; print"#L221#"; 'Regel 4, POSITON 1 PRINT "Getal4=";Var4; E=OFF print"#INIT#"; print"#CLR"; print"#L101#"; PRINT "Getal5=";Var5; print"#L201#"; PRINT "Getal6=";Var6; print"#L221#"; PRINT Aantal; print"#OFF#"; pause 150 GOTO Opstart #GeenOntvangst E=ON print"#ON_LCD#"; print"#INIT#"; print"#L101#"; print "****** Geen ontvangst ******"; print"#L201#"; print"Storing Kijk of de afzender goed aangeslo"; E=OFF print"#ON_LCD#"; print"#INIT#"; print"#L101#"; print "ten is. Spanning aangesloten "; print"#L201#"; print"of draadbreuk in de data kabel "; GOTO Opstart |
