Hello Patrick. > Cause: IIC-bus. The cause for the inaccurate bitwise access to the external ports is not the I²C bus. The reasons are the incorrect logical levels of the PCF outputs. This is a known error of the Station 2.0. > However my alarm system program is 4 kB long and complicated. Relais and leds act like crazy. There is no error in the program, I have been checking it for 3 weeks ! For example: all leds and relais are off. I order relay3=on and then LED2 goes on as well! Maybe you should send your code to someone who has access to a V2.0 C-Control. Or you post your source code here in the forum. What is the subversion of the operating system of your C-Control? Many greetings Dietmar Meine Homepage: http://ccintern.dharlos.de |
