 Re: Station-1 V2.0 Relais&Led Problem Kategorie: C-Control I V1.2/2.0 (von Patrick - 2.09.2006 0:51)
 Als Antwort auf Re: Station-1 V2.0 Relais&Led Problem von Dietmar - 30.08.2006 17:33
Patrick nutzt:  CC1-Station V2.0
Hello,
The subversion of my Station I 2.0 is 2.04
Is there a new version since last year ?
Did Conrad correct the issue of I2C for leds and relays on the Station?
In the meantime I found a solution for my program "alarm system" that did not work with ccbasic.
I translated the program into Basic++ 2006. I had to remove the recommended code for the relays and leds ( extport=io_station....etc ) because basic++ does not recognise that code.
I thought, this time the leds and relays will do crazy as soon as I start my alarm system.
Well excellent news: after few tests the leds and relays work as they should. Thank you basic++ !!
I just consider the leds and relays as digital outputs and they work fine!
Did other users notice the same with basic++ on the station I v2 ?
Regards,
Patrick - Brussels - Entschulding für Englisch, ich verstehe nur die Conrad Bedienungsanleitungen !
