Hello, The leds and relais on my C-Control-1 V2.0 do not respond correctly with my CC-basic program. The problem is know and Conrad offers a solution. Cause: IIC-bus. The solution is: define STATION_IO byte[3] and EXTPORT= STATION_IO ...and so on... works well for any small program. However my alarm system program is 4 kB long and complicated. Relais and leds act like crazy. There is no error in the program, I have been checking it for 3 weeks ! For example: all leds and relais are off. I order relay3=on and then LED2 goes on as well! My question is: if I step over to Basic++, will this problem be over ? Or will the problem remain ? Thanks for your help, Patrick - Brussels. |
