 Re: 2 x DS1612 Temperature Kategorie: Programmierung Basic (von Windt H.J. - 5.02.2006 16:52)
 Als Antwort auf Re: 2 x DS1612 Temperature von Hans - 5.02.2006 15:40
Hello,
I canÂ’t test this example but I think it should work.
Temperature IN is DS1621 addressed at &h90.
Temperature OUT is DS1621 addressed at &h92
Let me know how it works.
Greetings,
H.J. Windt
'**************** I/O PORTS ****************'
define lcd_backlight_off port[16]
'**************** VARIABLES ****************'
define configuration byte[1]
define iic_nack bit[7]
define iic_nack_count byte[2]
define iic_byte byte[3]
define ds1621_status byte[4]
define loop byte[5]
define temp_in word[4]
define temp_out word[5]
'**************** CONSTANTS ****************'
define ds1621_in_iic_address &h90
define ds1621_out_iic_address &h92
'****************** SETUP ******************'
put 0:print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:lcd_backlight_off = 0:print"#OFF#";
'***************** PROGRAM *****************'
#start
gosub get_ds1621_temperature
print"#ON_LCD#";
print"#L101#";:print"T in = ";temp_in/10;",";abs(temp_in-temp_in/10*10);:put&hdf:print"C  ";
print"#L201#";:print"Tout = ";temp_out/10;",";abs(temp_out-temp_out/10*10);:put&hdf:print"C  ";
print"#OFF#";
goto start
'*************** SUBROUTINES ***************'
#get_ds1621_temperature
for loop = 1 to 2
#ds1621_start_convert
print"#ON_IIC#";
print"#START#";
if loop = 1 then put ds1621_in_iic_address
if loop = 2 then put ds1621_out_iic_address
put &hee
print"#STOP#";
print"#OFF#";
gosub check_iic_nack
if iic_nack_count > 6 then gosub no_ack_from_ds1621
if iic_nack then goto ds1621_start_convert
#ds1621_check_conversion_done
print"#ON_IIC#";
print"#START#";
put &hac
print"#STOP#";
print"#OFF#";
if iic_nack then goto ds1621_pass_check_conversion_done
print"#ON_IIC#";
print"#START#";
if loop = 1 then put ds1621_in_iic_address + 1
if loop = 2 then put ds1621_out_iic_address + 1
get ds1621_status
print"#STOP#";
print"#OFF#";
#ds1621_pass_check_conversion_done
if iic_nack_count > 9 then gosub no_ack_from_ds1621
if iic_nack then goto ds1621_check_conversion_done
if (ds1621_status and 1) = 1 then if (ds1621_status and 128) = 0 then goto ds1621_check_conversion_done
#ds1621_read_temp
print"#ON_IIC#";
print"#START#";
put &haa
print"#STOP#";
print"#OFF#";
if iic_nack then goto pass_ds1621_read_temp
print"#ON_IIC#";
print"#START#";
get iic_byte
if loop = 1 then if iic_byte > 127 then temp_in = (&hff00 + iic_byte) * 10 else temp_in = iic_byte * 10
if loop = 2 then if iic_byte > 127 then temp_out = (&hff00 + iic_byte) * 10 else temp_out = iic_byte * 10
get iic_byte
if loop = 1 then if (iic_byte and 128) = 128 then temp_in = temp_in + 5
if loop = 2 then if (iic_byte and 128) = 128 then temp_out = temp_out + 5
print"#STOP#";
print"#OFF#";
#pass_ds1621_read_temp
if iic_nack then goto ds1621_read_temp
if temp_in = -600 then goto ds1621_start_convert
if temp_out = -600 then goto ds1621_start_convert
next
return
#check_iic_nack
print"#ON_CONFIG#";
get configuration
if not iic_nack then goto pass_iic_nack_clear
iic_nack = 0
put configuration
iic_nack = 1
iic_nack_count = iic_nack_count + 1
print"#OFF#";
return
#pass_iic_nack_clear
iic_nack_count = 0
print"#OFF#";
return
'******* INITIALIZATION SUBROUTINES ********'
'****************** DATA *******************'
'************* ERROR MESSAGES **************'
#no_ack_from_ds1621
beep 1,1,1:beep 10,1,1:beep 1,1,1:beep 10,1,1
print"#ON_LCD#";
print"#CLR#";
print"IIC ERROR:";
print"#L201#";
print"DS1621 not found";
pause 300
print"#CLR#";
print"#OFF#";
return
Re: 2 x DS1612 Temperature (von Hans - 5.02.2006 17:33)
    Re: 2 x DS1612 Temperature (von Windt H.J. - 5.02.2006 17:41)
        Re: 2 x DS1612 Temperature (von Windt H.J. - 6.02.2006 13:17)
            2 x DS1621 v1.3 (von Windt H.J. - 6.02.2006 13:35)
                Re: 2 x DS1621 v1.3 (von Hans - 8.02.2006 17:55)
                    Re: 2 x DS1621 v1.4 (von Windt H.J. - 8.02.2006 19:13)
                       Re: 2 x DS1621 v1.4 (von Hans - 8.02.2006 20:00)
