 Re: 2 x DS1621 v1.4 Kategorie: Programmierung Basic (von Hans - 8.02.2006 20:00)
 Als Antwort auf Re: 2 x DS1621 v1.4 von Windt H.J. - 8.02.2006 19:13
Hans nutzt:  CC1-M-Unit V1.2/2.0
Thank you
Its working now
I have learn a lot and now I can go on with it
Hans
> Hello,
> Thank you very much for warning me about this!
> The problem was not with the variables temp_in or temp_out but with the way they are displayed.
> I guess I missed this while testing my example.
> Here is the corrected version, v1.4
> Let me know how it works out.
> Greetings,
> H.J. Windt
> '* 2xDS1621 v1.4*'
> '**************** I/O PORTS ****************'
> define lcd_backlight_off port[16]
> '**************** VARIABLES ****************'
> define configuration byte[1]
> define iic_nack bit[7]
> define ds1621_in_error bit[9]
> define ds1621_out_error bit[10]
> define iic_nack_count byte[3]
> define iic_byte byte[4]
> define ds1621_status byte[5]
> define loop byte[6]
> define temp_in word[4]
> define temp_out word[5]
> '**************** CONSTANTS ****************'
> define ds1621_in_iic_address &h90
> define ds1621_out_iic_address &h92
> '****************** SETUP ******************'
> put 0:print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:lcd_backlight_off = 0:print"#OFF#";
> '***************** PROGRAM *****************'
> #start
> gosub get_ds1621_temperature
> print"#ON_LCD#";
> print"#L101#";:print"T in = ";
> if temp_in < 0 then print"-";
> print abs(temp_in/10);",";abs(temp_in-temp_in/10*10);:put&hdf:print"C  ";
> print"#L108#";:if ds1621_in_error <> 0 then print"IIC Error   ";
> print"#L201#";:print"Tout = ";
> if temp_out < 0 then print"-";
> print abs(temp_out/10);",";abs(temp_out-temp_out/10*10);:put&hdf:print"C  ";
> print"#L208#";:if ds1621_out_error <> 0 then print"IIC Error   ";
> print"#OFF#";
> goto start
> '*************** SUBROUTINES ***************'
> #get_ds1621_temperature
> ds1621_in_error = 0
> ds1621_out_error = 0
> for loop = 1 to 2
> #ds1621_start_convert
> print"#ON_IIC#";
> print"#START#";
> gosub ds1621_write_address
> put &hee
> print"#STOP#";
> print"#OFF#";
> gosub check_iic_nack
> if iic_nack_count > 6 then goto no_ack_from_ds1621
> if iic_nack then goto ds1621_start_convert
> #ds1621_check_conversion_done
> print"#ON_IIC#";
> print"#START#";
> put &hac
> print"#STOP#";
> print"#OFF#";
> if iic_nack then goto ds1621_pass_check_conversion_done
> print"#ON_IIC#";
> print"#START#";
> gosub ds1621_read_address
> get ds1621_status
> print"#STOP#";
> print"#OFF#";
> #ds1621_pass_check_conversion_done
> if iic_nack_count > 9 then goto no_ack_from_ds1621
> if iic_nack then goto ds1621_check_conversion_done
> if (ds1621_status and 1) = 1 then if (ds1621_status and 128) = 0 then goto ds1621_check_conversion_done
> #ds1621_read_temp
> print"#ON_IIC#";
> print"#START#";
> put &haa
> print"#STOP#";
> print"#OFF#";
> if iic_nack then goto pass_ds1621_read_temp
> print"#ON_IIC#";
> print"#START#";
> get iic_byte
> if loop = 1 then if iic_byte > 127 then temp_in = (&hff00 + iic_byte) * 10 else temp_in = iic_byte * 10
> if loop = 2 then if iic_byte > 127 then temp_out = (&hff00 + iic_byte) * 10 else temp_out = iic_byte * 10
> get iic_byte
> if loop = 1 then if (iic_byte and 128) = 128 then temp_in = temp_in + 5
> if loop = 2 then if (iic_byte and 128) = 128 then temp_out = temp_out + 5
> print"#STOP#";
> print"#OFF#";
> #pass_ds1621_read_temp
> if iic_nack then goto ds1621_read_temp
> if temp_in = -600 then goto ds1621_start_convert
> if temp_out = -600 then goto ds1621_start_convert
> #pass_get_ds1621_temperature
> next
> return
> #ds1621_write_address
> if loop = 1 then put ds1621_in_iic_address
> if loop = 2 then put ds1621_out_iic_address
> return
> #ds1621_read_address
> if loop = 1 then put ds1621_in_iic_address + 1
> if loop = 2 then put ds1621_out_iic_address + 1
> return
> #check_iic_nack
> print"#ON_CONFIG#";
> get configuration
> if not iic_nack then goto pass_iic_nack_clear
> iic_nack = 0
> put configuration
> iic_nack = 1
> iic_nack_count = iic_nack_count + 1
> print"#OFF#";
> return
> #pass_iic_nack_clear
> iic_nack_count = 0
> print"#OFF#";
> return
> '******* INITIALIZATION SUBROUTINES ********'
> '****************** DATA *******************'
> '************* ERROR MESSAGES **************'
> #no_ack_from_ds1621
> beep 1,1,1:beep 10,1,1:beep 1,1,1:beep 10,1,1
> if loop = 1 then ds1621_in_error = 1
> if loop = 2 then ds1621_out_error = 1
> goto pass_get_ds1621_temperature
