Vielen danke!!! Ja, das war was ich wollte! Danke schön! Dave > Hello, > I hope this helps you out. > Greetings, > H.J. Windt > > > > Port 01: Nu > Port 02: IR Transceiver Module Receive or 433MHz AM Receiver Module > Port 03: IR Transceiver Module Transmit or 433MHz AM Transmitter Module > Port 04: Nu > Port 05: Relay Module Relay 1 > Port 06: Relay Module Relay 2 > Port 07: Relay Module Relay 3 > Port 08: Relay Module Relay 4 > > Port 09: LCD databus 4 & IIC (I²C) bus SDA > Port 10: LCD databus 5 & IIC (I²C) bus SCL > Port 11: LCD databus 6 > Port 12: LCD databus 7 > Port 13: LCD rw > Port 14: LCD rs > Port 15: LCD en > Port 16: LCD backlight/ 0 = on 1 = 0ff > > > Hallo! > > > > Just a brief question: what's the function of every digital port? I know that port 16 is usually used for the Light and LCD is somewhere between 10 and 15. Could someone tell me why are 2 and 3 for? And the others? I couldn't find it at the manual... > > > > Thanks!! > > > > Dave |
