 Re: ports functionality Kategorie: C-Control I V1.1 (von Windt H.J. - 9.01.2006 20:11)
 Als Antwort auf ports functionality von Dave Smith - 9.01.2006 18:52
Hello,
I hope this helps you out.
Greetings,
H.J. Windt
Port 01: Nu
Port 02: IR Transceiver Module Receive or 433MHz AM Receiver Module
Port 03: IR Transceiver Module Transmit or 433MHz AM Transmitter Module
Port 04: Nu
Port 05: Relay Module Relay 1
Port 06: Relay Module Relay 2
Port 07: Relay Module Relay 3
Port 08: Relay Module Relay 4
Port 09: LCD databus 4 & IIC (I²C) bus SDA
Port 10: LCD databus 5 & IIC (I²C) bus SCL
Port 11: LCD databus 6
Port 12: LCD databus 7
Port 13: LCD rw
Port 14: LCD rs
Port 15: LCD en
Port 16: LCD backlight/ 0 = on 1 = 0ff
> Hallo!
> Just a brief question: what's the function of every digital port? I know that port 16 is usually used for the Light and LCD is somewhere between 10 and 15. Could someone tell me why are 2 and 3 for? And the others? I couldn't find it at the manual...
> Thanks!!
> Dave
Re: ports functionality (von Dave Smith - 10.01.2006 10:20)
