Bedankt Mario Ik heb je voorstel uitgeprobeerd maar het werkt jammer genoeg niet I have tried out your proposal but it works unfortunately not I have now simplified it AND Now the data is coming direct from the C-control M-Unit 2.0 PIN 52 instead of the IC RS232 and that works Now there is made a TEXT file test A.txt But unfortunately there is no data written We are nearly there, wat can be possibly wrong print "at+create testA.txt" 'Maakt een file testA.txt. pause 150 '3 sec. #start Print "at+datastream " ' To Send Data PAUSE 150 PRINT "DIT IS EEN TEST" PRINT "Alles wat hier staat moet zichtbaar zijn" PAUSE 25 'pause 0,5 sec PRINT "+" 'Stop recording PAUSE 25 PRINT "+" 'Stop recording PAUSE 25 PRINT "+" 'Stop recording pause 25 END > Hello, > > I don't have experience with the CF-Module, but I'm interested for it. > > The first command after the power-on or restart has a delay of 3 seconds. While this time the CF-Module "learns" how the commands will be closed (with CR,LF or just LF). The command "print" sends automatically CR,LF. > > There is another error in your program. The stop-sequence after writing data will also close the file. Before writing next data you have to open it. > After creating the file (and waiting for 3 seconds) you should close it with "at+close". At the beginning of the loop you should open the file for write with "at+append test.txt". So the program should work. I made the changes in your program. > > Greetings Mario > > > Hallo > > > > Is there someone who has experience with the CF memory card of Avisaro? > > I only want to write data, but I cant get it done > > It looked so simple, but what is going wrong? > > > > Hier het test progr. > > > > define test word[1] > > > > Year=05:Month=11:Day=12:HOUR=7:Minute=0:Second=0 'woensdag, 12.00.00 > > hour=11:minute=20:second=00 > > pause 2 > > print "at+create test.txt" 'Maakt een file test.txt. > > pause 150 ' Waiting 3 sec. for "learning" > > print "at+close" ' close file > > > > > > > > #start > > print "at+append test.txt" ' open file for write and appending data > > Print "at+datastream " ' To Send Data > > pause 50 > > test=test+2 > > print day/10; > > print day mod 10; > > print"-"; > > print Month/10; > > print month mod 10; > > print"-20"; > > print Year/10; > > print Year mod 10, > > > > print hour/10; > > print hour mod 10; > > print":"; > > print minute/10; > > print minute mod 10; > > print ":"; > > print second/10; > > print second mod 10, > > > > print test > > pause 50 > > print "+" 'Stop recording 3x > > pause 50 > > print "+" 'Stop recording > > pause 50 > > print "+" 'Stop recording > > pause 50 > > > > pause 500 '10sec. > > > > goto Start > > > > > > > |
