 Re: CF card van Avisaro Kategorie: Programmierung Basic (von Hans - 30.11.2005 22:35)
 Als Antwort auf Re: CF card van Avisaro von Windt H.J. - 30.11.2005 21:58
Hans nutzt:  CC1-M-Unit V1.2/2.0
Dit ziet er geweldig uit
This looks good
I did send the module back for checking if it is really brooken
and to firm it to I2C
That is what I am waiting for
As soon as I gets it I will try it out imediately and let you now if it works
Thank you very much for all your help
> Hello,
> Try this out.
> Greetings,
> H.J. Windt
> '**************** I/O PORTS ****************'
> define lcd_backlight_off port[16]
> '**************** A/D PORTS ****************'
> '**************** D/A PORTS ****************'
> '**************** VARIABLES ****************'
> define control_flags byte[1]
> define iic_nack bit[7]
> define iic_nack_count byte[2]
> define var1 byte[3]
> define var2 byte[4]
> define var3 byte[5]
> '**************** CONSTANTS ****************'
> define avisaro_iic_address 73
> '****************** SETUP ******************'
> put 0
> print"#ON_LCD#";"#INIT#";"#CLR#";"#OFF#";:lcd_backlight_off = 0
> '***************** PROGRAM *****************'
> #start
> var1 = 12
> var2 = 34
> var3 = 45
> gosub write_data_to_avisaro
> #endloop
> beep 5,1,1
> goto endloop
> '*************** SUBROUTINES ***************'
> #write_data_to_avisaro
> if second > 57 then goto write_data_to_avisaro
> print"#ON_IIC#";
> print"#START#";
> put avisaro_iic_address
> put hour
> put minute
> put day
> put month
> put year
> put var1
> put var2
> put var3
> print"#STOP#";
> print"#OFF#";
> gosub check_iic_nack
> if iic_nack_count > 27 then goto no_ack_from_avisaro
> if iic_nack then goto write_data_to_avisaro
> return
> #check_iic_nack
> print"#ON_CONFIG#";
> get control_flags
> if not iic_nack then goto pass_iic_nack_clear
> iic_nack = 0
> put control_flags
> iic_nack = 1
> iic_nack_count = iic_nack_count + 1
> print"#OFF#";
> return
> #pass_iic_nack_clear
> iic_nack_count = 0
> print"#OFF#";
> return
> '********* CALIBRATION SUBROUTINES *********'
> '****************** DATA *******************'
> '************* ERROR MESSAGES **************'
> #no_ack_from_avisaro
> beep 1,1,1:beep 10,1,1:beep 1,1,1:beep 10,1,1
> print"#ON_LCD#";"#CLR#";"IIC ERROR:";"#L201#";"AVISARO NACK";
> pause 300
> print"#CLR#";"#OFF#";
> return
