 Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen Kategorie: C-Control I V1.2/2.0 (von Henrik, Homepage - 26.10.2005 15:15)
 Als Antwort auf Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen von Daniel - 26.10.2005 14:36
Henrik nutzt:  CC1-M-Unit V1.2/2.0, Micro
Hello Daniel,
> Thank You Henrik, but I'm a bit old fashioned (and >60) and I do use traditional CCBasic 2.0 with a driver
> developed by Die Hard (see below), modified recently by himself. I would rather be able to modify the driver for 11 bits precision.
well, to change Die Hards sample is not very usefull.
But anyway, if you want to stick to CC-Basic - I've written a sample for this Purpose in former times. Sorry the program ist written with explanations in German, hope you come come along.
Here ist is ( for you the only important thing is the Subroutine Readtemp):
'Test für I2C mit Dallas Temperatursensor
'---- Variablen definieren-----------------------------------------
define value      word
define DEV1       byte
define TEMP       byte
define DATA       byte
define temperatur byte
define counter    byte
define slope      byte
define keyboard   ad[7]
#INIT
print"#ON_CONFIG#";             'UMGELEITET
get TEMP                        'den aktuellen Wert lesen
put (TEMP or &B0011000)         'Bits setzten und zurück schreiben
print"#OFF#";                   'Umleitung abschalten
print"#ON_LCD#";
print"#INIT#";
print"1621 TEST";:pause 50
print"#CLR#";:print"#OFF#";
'--------- HAUPTPROGRAMM -----------------------------------------
#genau
dev1 = 144
gosub READTEMP
print "#ON_LCD#";
print "#L101#";
print value/10; ","; value mod 10;
'pause 50
print "#OFF";
goto genau
#READTEMP
print "#ON_IIC#";
print"#START#";
put DEV1
put &hEE       'temperaturmessung anstoßen
print"#STOP#";
pause 10
print"#START#";
put DEV1
put &h22       'temperaturmessung stoppen
print"#STOP#";
print"#START#";
put DEV1
put &hAA           'temperaturmessung Lesekommando
print"#STOP#";
print"#START#";
put DEV1+1         'lowtemperaturbyte auslesen
get value
temperatur = value
'get value          'dummy auslesung
print"#STOP#";
print"#START#";
put DEV1
put &hA8           'Counter Lesekommando
print"#STOP#";
print"#START#";
put DEV1+1         'Counter auslesen
get value
counter = value
print"#STOP#";
print"#START#";
put DEV1
put &hA9           'Slope Lesekommando
print"#STOP#";
print"#START#";
put DEV1+1         'Slope auslesen
get value
slope = value
print"#STOP#";
print"#OFF#";
value = ((temperatur*100-25) + ((slope-counter)*100/slope*100)/100)/10
return
Best regards
Henrik
Meine Homepage: http://www.henrik-reimers.de/control/
Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen (von Daniel - 26.10.2005 17:16)
    Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen (von Daniel - 29.10.2005 9:00)
