 Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen Kategorie: C-Control I V1.2/2.0 (von Daniel - 29.10.2005 9:00)
 Als Antwort auf Re: DS1631: 10, 11 oder 12 Bits Konfigurieren/lesen von Daniel - 26.10.2005 17:16
Daniel nutzt:  CC1-M-Unit V1.2/2.0
> > Hello Daniel,
> > > Thank You Henrik, but I'm a bit old fashioned (and >60) and I do use traditional CCBasic 2.0 with a driver
> > > developed by Die Hard (see below), modified recently by himself. I would rather be able to modify the driver for 11 bits precision.
> > well, to change Die Hards sample is not very usefull.
> > But anyway, if you want to stick to CC-Basic - I've written a sample for this Purpose in former times. Sorry the program ist written with explanations in German, hope you come come along.
> > Here ist is ( for you the only important thing is the Subroutine Readtemp):
> > 'Test für I2C mit Dallas Temperatursensor
> > '---- Variablen definieren-----------------------------------------
> > define value      word
> > define DEV1       byte
> > define TEMP       byte
> > define DATA       byte
> > define temperatur byte
> > define counter    byte
> > define slope      byte
> > define keyboard   ad[7]
> > #INIT
> > print"#ON_CONFIG#";             'UMGELEITET
> > get TEMP                        'den aktuellen Wert lesen
> > put (TEMP or &B0011000)         'Bits setzten und zurück schreiben
> > print"#OFF#";                   'Umleitung abschalten
> > print"#ON_LCD#";
> > print"#INIT#";
> > print"1621 TEST";:pause 50
> > print"#CLR#";:print"#OFF#";
> > '--------- HAUPTPROGRAMM -----------------------------------------
> > #genau
> > dev1 = 144
> > gosub READTEMP
> > print "#ON_LCD#";
> > print "#L101#";
> > print value/10; ","; value mod 10;
> > 'pause 50
> > print "#OFF";
> > goto genau
> > #READTEMP
> > print "#ON_IIC#";
> > print"#START#";
> > put DEV1
> > put &hEE       'temperaturmessung anstoßen
> > print"#STOP#";
> > pause 10
> > print"#START#";
> > put DEV1
> > put &h22       'temperaturmessung stoppen
> > print"#STOP#";
> > print"#START#";
> > put DEV1
> > put &hAA           'temperaturmessung Lesekommando
> > print"#STOP#";
> > print"#START#";
> > put DEV1+1         'lowtemperaturbyte auslesen
> > get value
> > temperatur = value
> > 'get value          'dummy auslesung
> > print"#STOP#";
> > print"#START#";
> > put DEV1
> > put &hA8           'Counter Lesekommando
> > print"#STOP#";
> > print"#START#";
> > put DEV1+1         'Counter auslesen
> > get value
> > counter = value
> > print"#STOP#";
> > print"#START#";
> > put DEV1
> > put &hA9           'Slope Lesekommando
> > print"#STOP#";
> > print"#START#";
> > put DEV1+1         'Slope auslesen
> > get value
> > slope = value
> > print"#STOP#";
> > print"#OFF#";
> > value = ((temperatur*100-25) + ((slope-counter)*100/slope*100)/100)/10
> > return
> > Best regards
> > Henrik
> Thanks Henrik, I'll test this in the coming week. Regards. Daniel
> PS: German is not a problem but I did loose practice in writing.
Works fine Henrik, thanks for the help...Daniel...www.dufour.ch
