Thanks, I'll try it out. Greetings, H.J. Windt > > > Hello, > > Can I freely use the IIC bus without the LCD connected or must I first use the initialize LCD command even without the LCD to use the IIC bus? > > Greetings, > > H.J. Windt > > > > > > > > Hello, > you can use the bus w/o initializing the LCD if it is no one is connected. > But possibly (i do not remember) you have to switch the ports 9/10 to output > before using the bus. > ciao.... |
