> Hello, > Can I freely use the IIC bus without the LCD connected or must I first use the initialize LCD command even without the LCD to use the IIC bus? > Greetings, > H.J. Windt > > > Hello, you can use the bus w/o initializing the LCD if it is no one is connected. But possibly (i do not remember) you have to switch the ports 9/10 to output before using the bus. ciao.... |
