 Re: Display 4x20 Scroll Kategorie: Programmierung Basic (von Hans - 24.09.2005 15:18)
 Als Antwort auf Re: Display 4x20 Scroll von Windt H.J. - 24.09.2005 14:04
Hans nutzt:  CC1-M-Unit V1.2/2.0
hallo
thank you very much for reacting so fast
i have tested the program, but unfortunatelyit does not work
it is difficult for me to say what part of the program does not work
the fist line of the display gives a report, and that is not good
i have now 4 lines with the reports and now and then the arrows are shown on the display
i hope you will have the solution for me
Greeting
Hans
> Hello,
> I'm not sure but try this out.
> I have also updated my LCD sub's
> Greetings,
> H.J. Windt
> '-----port 2 lcd connections-----'
> define db4 port[9]  'databus 4'
> define db5 port[10] 'databus 5'
> define db6 port[11] 'databus 6'
> define db7 port[12] 'databus 7'
> define rw port[13] '0 = write to lcd display / 1 = read from lcd display'
> define rs port[14] '0 = command / 1 = data'
> define en port[15] '1 to 0 = enable'
> define lcd_light_off port[16] '(off)0 = light on / (on)1 = light off'
> '******************************************************* VARIABLES *******************************************************'
> define data byte[1]'data / used for translating byte into bits and vice versa for I/O of port 2 (lcd port), -'
> define bit1 bit[1] '- needed because of a bug in the CC1 M2.01 system'
> define bit2 bit[2]
> define bit3 bit[3]
> define bit4 bit[4]
> define bit5 bit[5]
> define bit6 bit[6]
> define bit7 bit[7]
> define bit8 bit[8] '-----------------------------------------------------------------------------------------'
> define adr byte[2] 'address code'
> define cmd byte[3] 'command code'
> define dat byte[4] 'data code'
> define dat2 byte[5]
> define loop byte[6]
> '******************************************************** SET UP *********************************************************'
> print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:print"#OFF#";:lcd_light_off = 0  'initialize lcd display'
> gosub character_build
> DEFINE UP       PORT[1]
> DEFINE DOWN   PORT[2]
> DEFINE I             BYTE[7]
> DEFINE AanTal        BYTE[8]
> DEFINE IngangTotaal  WORD[5]
> DEFINE TEMP          WORD[6]
> DEFINE AantalTot     BYTE[13]
> define start_print byte[14]
> start_print = 1
> print"#ON_LCD#";
> #Start
> IngangTotaal=31    'voor simulate aantaltot is then 5
> GOSUB TelaantalTot
> #SetDisplay
> PRINT "#L101#";         'Regel 1, POSITON 1
> PRINT "Er zijn ";
> PRINT AantalTot;
> PRINT "meldingen";
> Temp=InGangTotaal
> Aantal = 0
> FOR I=1 TO 16
> if I >= start_print then IF (Temp AND 1)<>0 THEN GOSUB Tekst
> Temp=Temp SHR 1
> IF Aantal>3 THEN GOSUB DownSet
> IF Aantal>4 THEN GOSUB UPSet
> NEXT
> IF DOWN=ON THEN if start_print - 1 < 1 then start_print = 1 else start_print = start_print - 1
> if down = on then pause 10
> if up = on then if start_print + 1 > 16 then start_print = 16 else start_print = start_print + 1
> if up = on then pause 10
> GOTO Start
> #Tekst
> Aantal=Aantal+1
> IF aantal=1 THEN PRINT "#L201#";       'Regel 2, POSITON 1
> IF aantal=2 THEN PRINT "#L121#";       'Regel 3, POSITON 1
> IF Aantal=3 THEN print"#L221#";        'Regel 4, POSITON 1
> IF I=1  THEN print"Ingang 1            ";
> IF I=2  THEN print"Ingang 2            ";
> IF I=3  THEN print"Ingang 3            ";
> IF I=4  THEN print"Ingang 4            ";
> IF I=5  THEN print"Ingang 5            ";
> IF I=6  THEN print"Ingang 6            ";
> IF I=7  THEN print"Ingang 7            ";
> IF I=8  THEN print"Ingang 8            ";
> IF I=9  THEN print"Ingang 9            ";
> IF I=10 THEN print"Ingang 10           ";
> IF I=11 THEN print"Ingang 11           ";
> IF I=12 THEN print"Ingang 12           ";
> RETURN
> #TelAantalTot
> AantalTot = 0
> Temp=InGangTotaal
> FOR I=1 TO 16
> IF (Temp AND 1)<>0 THEN AantalTot=AantalTot+1
> Temp=Temp SHR 1
> NEXT
> RETURN
> #DOWNSet
> print"#L240#";           'Regel 4, POSITON 20
> put&h08                  'UP'
> RETURN
> #UPSet
> PRINT "#L220#";       'Regel 2, POSITON 20
> put&h09                  'DOWN'
> RETURN
> #command_to_lcd
> gosub busy_flag_check_from_lcd
> deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 0:en = 0           'setup for transmitting command to lcd display'
> data = cmd / 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en   'HIGH NIBBLE command to lcd'
> data = cmd mod 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE command to lcd'
> return
> #data_to_CG_ram_lcd
> cmd = &b01000000 or adr : gosub command_to_lcd
> #put_data_into_lcd
> deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 1:en = 0           'setup for transmitting data to lcd display'
> data = dat / 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en   'HIGH NIBBLE data to lcd'
> data = dat mod 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE data to lcd'
> return
> #busy_flag_check_from_lcd
> deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs = 0:en = 1 'setup for reading busy flag'
> bit8 = db7:bit7 = db6:bit6 = db5:bit5 = db4                        'HIGH NIBBLE data from lcd'
> pulse en:bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:en = 0        'LOW NIBBLE data from lcd'
> if bit8 then goto busy_flag_check_from_lcd 'bit 8 of data is the busy flag bit / 1 = lcd is busy / 0 = lcd is ready'
> return
> #character_build 'generates characters in lcd ram from characterbuild table / 8 characters of 5X8 pixels'
> for adr = 0 to 63                'lcd display character generation (CG) address'
> looktab characterbuild, adr, dat 'lcd data for character generation'
> gosub data_to_CG_ram_lcd         'set character generation data in CG address'
> next
> return
> '                 (CG    dat     adr) 000/XXXXX  first 3 bits are not used/ last 5 bits are for character generation   '
> table characterbuild &b00000100 '(0)  000/  1  ' character build data for antenna symbol/ read from DD-ram address &h08'
>                      &b00001110 '(1)  000/ 111 '                                                               *put&h08*'
>                      &b00011111 '(2)  000/11111'
>                      &b00000100 '(3)  000/  1  '
>                      &b00000100 '(4)  000/  1  '
>                      &b00000100 '(5)  000/  1  '
>                      &b00000100 '(6)  000/  1  '
>                      &b00000000 '(7)  000/     '-----------------------------------------'
>                      &b00000100 '(8)  000/  1  ' character build data for heart/ read from DD-ram address &h09'
>                      &b00000100 '(9)  000/  1  '                                                      *put&h09*'
>                      &b00000100 '(10) 000/  1  '
>                      &b00000100 '(11) 000/  1  '
>                      &b00011111 '(12) 000/11111'
>                      &b00001110 '(13) 000/ 111 '
>                      &b00000100 '(14) 000/  1  '
>                      &b00000000 '(15) 000/     '-----------------------------------------'
>                      &b00000000 '(16) 000/     ' character build data for happy/ read from DD-ram address &h0a'
>                      &b00000000 '(17) 000/     '                                                      *put&h0a*'
>                      &b00001010 '(18) 000/ 1 1 '
>                      &b00000000 '(19) 000/     '
>                      &b00000100 '(20) 000/  1  '
>                      &b00010001 '(21) 000/1   1'
>                      &b00001110 '(22) 000/ 111 '
>                      &b00000000 '(23) 000/     '-----------------------------------------'
>                      &b00011111 '(24) 000/11111 character build data for window/ read from DD-ram address &h0b'
>                      &b00010101 '(25) 000/1 1 1'                                                      *put&h0b*'
>                      &b00010101 '(26) 000/1 1 1'
>                      &b00011111 '(27) 000/11111'
>                      &b00010101 '(28) 000/1 1 1'
>                      &b00010101 '(29) 000/1 1 1'
>                      &b00011111 '(30) 000/11111'
>                      &b00011111 '(31) 000/11111'-----------------------------------------'
>                      &b00000000 '(32) 000/00000 empty place for character build data/ read from DD-ram address &h0c'
>                      &b00000000 '(33) 000/00000'                                                           *put&h0c*'
>                      &b00000000 '(34) 000/00000'
>                      &b00000000 '(35) 000/00000'
>                      &b00000000 '(36) 000/00000'
>                      &b00000000 '(37) 000/00000'
>                      &b00000000 '(38) 000/00000'
>                      &b00000000 '(39) 000/00000 -----------------------------------------'
>                      &b00000000 '(40) 000/00000 empty place for character build data/ read from DD-ram address &h0d'
>                      &b00000000 '(41) 000/00000'                                                           *put&h0d*'
>                      &b00000000 '(42) 000/00000'
>                      &b00000000 '(43) 000/00000'
>                      &b00000000 '(44) 000/00000'
>                      &b00000000 '(45) 000/00000'
>                      &b00000000 '(46) 000/00000'
>                      &b00000000 '(47) 000/00000 -----------------------------------------'
>                      &b00000000 '(48) 000/00000 empty place for character build data/ read from DD-ram address &h0e'
>                      &b00000000 '(49) 000/00000'                                                           *put&h0e*'
>                      &b00000000 '(50) 000/00000'
>                      &b00000000 '(51) 000/00000'
>                      &b00000000 '(52) 000/00000'
>                      &b00000000 '(53) 000/00000'
>                      &b00000000 '(54) 000/00000'
>                      &b00000000 '(55) 000/00000 -----------------------------------------'
>                      &b00000000 '(56) 000/00000 empty place for character build data/ read from DD-ram address &h0f'
>                      &b00000000 '(57) 000/00000'                                                           *put&h0f*'
>                      &b00000000 '(58) 000/00000'
>                      &b00000000 '(59) 000/00000'
>                      &b00000000 '(60) 000/00000'
>                      &b00000000 '(61) 000/00000'
>                      &b00000000 '(62) 000/00000'
>                      &b00000000 '(63) 000/00000 -----------------------------------------'
> tabend
Re: Display 4x20 Scroll (von Windt H.J. - 24.09.2005 15:32)
    Re: Display 4x20 Scroll (von Hans - 24.09.2005 16:09)
        Re: Display 4x20 Scroll (von Windt H.J. - 24.09.2005 22:59)
            Re: Display 4x20 Scroll (von Hans - 25.09.2005 13:14)
                Re: Display 4x20 Scroll (von Windt H.J. - 25.09.2005 14:03)
                    Re: Display 4x20 Scroll (von Hans - 25.09.2005 15:18)
                       Re: Display 4x20 Scroll (von Windt H.J. - 25.09.2005 21:39)
    Re: Display 4x20 Scroll (von Windt H.J. - 24.09.2005 15:39)
        Re: Display 4x20 Scroll (von Windt H.J. - 24.09.2005 16:15)
