sorry, I forgot something again and made some changes. try this out '-----port 2 lcd connections-----' define db4 port[9] 'databus 4' define db5 port[10] 'databus 5' define db6 port[11] 'databus 6' define db7 port[12] 'databus 7' define rw port[13] '0 = write to lcd display / 1 = read from lcd display' define rs port[14] '0 = command / 1 = data' define en port[15] '1 to 0 = enable' define lcd_light_off port[16] '(off)0 = light on / (on)1 = light off' '******************************************************* VARIABLES *******************************************************' define data byte[1]'data / used for translating byte into bits and vice versa for I/O of port 2 (lcd port), -' define bit1 bit[1] '- needed because of a bug in the CC1 M2.01 system' define bit2 bit[2] define bit3 bit[3] define bit4 bit[4] define bit5 bit[5] define bit6 bit[6] define bit7 bit[7] define bit8 bit[8] '-----------------------------------------------------------------------------------------' define adr byte[2] 'address code' define cmd byte[3] 'command code' define dat byte[4] 'data code' define dat2 byte[5] define loop byte[6] '******************************************************** SET UP *********************************************************' print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:print"#OFF#";:lcd_light_off = 0 'initialize lcd display' gosub character_build '*************************************************************************************************************************' DEFINE UP PORT[1] DEFINE DOWN PORT[2] DEFINE I BYTE[7] DEFINE AanTal BYTE[8] DEFINE IngangTotaal WORD[5] DEFINE TEMP WORD[6] DEFINE AantalTot BYTE[13] define start_print byte[14] start_print = 1 print"#ON_LCD#"; #Start IngangTotaal=31 'voor simulate aantaltot is then 5 GOSUB TelaantalTot #SetDisplay PRINT "#L101#"; 'Regel 1, POSITON 1 PRINT "Er zijn "; PRINT AantalTot; PRINT "meldingen "; Temp=InGangTotaal if AantalTot = 0 then gosub clear_last_three_lines Aantal = 0 FOR I=1 TO 16 if I >= start_print then IF (Temp AND 1)<>0 THEN GOSUB Tekst Temp=Temp SHR 1 IF Aantal>3 THEN GOSUB DownSet IF Aantal>4 THEN GOSUB UPSet NEXT IF DOWN=ON THEN if start_print - 1 < 1 then start_print = 1 else start_print = start_print - 1 if down = on then pause 10 if up = on then start_print = start_print + 1 if up = on then pause 10 if AantalTot < 4 then start_print = 1 if AantalTot > 3 then if start_print > (AantalTot - 2) then start_print = AantalTot - 2 GOTO Start #Tekst Aantal=Aantal+1 if aantal = 1 then gosub clear_last_three_lines if aantal = 2 then gosub clear_last_two_lines if aantal = 3 then gosub clear_last_line IF aantal=1 THEN PRINT "#L201#"; 'Regel 2, POSITON 1 IF aantal=2 THEN PRINT "#L121#"; 'Regel 3, POSITON 1 IF Aantal=3 THEN print"#L221#"; 'Regel 4, POSITON 1 if aantal > 3 then return IF I=1 THEN print"Ingang 1 "; IF I=2 THEN print"Ingang 2 "; IF I=3 THEN print"Ingang 3 "; IF I=4 THEN print"Ingang 4 "; IF I=5 THEN print"Ingang 5 "; IF I=6 THEN print"Ingang 6 "; IF I=7 THEN print"Ingang 7 "; IF I=8 THEN print"Ingang 8 "; IF I=9 THEN print"Ingang 9 "; IF I=10 THEN print"Ingang 10 "; IF I=11 THEN print"Ingang 11 "; IF I=12 THEN print"Ingang 12 "; RETURN #clear_last_three_lines print "#L201#"; print" "; #clear_last_two_lines print "#L121#"; print" "; #clear_last_line print"#L221#"; print" "; return #TelAantalTot AantalTot = 0 Temp=InGangTotaal FOR I=1 TO 16 IF (Temp AND 1)<>0 THEN AantalTot=AantalTot+1 Temp=Temp SHR 1 NEXT RETURN #DOWNSet print"#L240#"; 'Regel 4, POSITON 20 put&h08 'UP' RETURN #UPSet PRINT "#L220#"; 'Regel 2, POSITON 20 put&h09 'DOWN' RETURN '*************************************************************************************************************************' #command_to_lcd gosub busy_flag_check_from_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 0:en = 0 'setup for transmitting command to lcd display' data = cmd / 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'HIGH NIBBLE command to lcd' data = cmd mod 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE command to lcd' return '*************************************************************************************************************************' #data_to_CG_ram_lcd cmd = &b01000000 or adr : gosub command_to_lcd #put_data_into_lcd gosub busy_flag_check_from_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 1:en = 0 'setup for transmitting data to lcd display' data = dat / 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'HIGH NIBBLE data to lcd' data = dat mod 16:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE data to lcd' return '*************************************************************************************************************************' #busy_flag_check_from_lcd deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs = 0:en = 1 'setup for reading busy flag' bit8 = db7:bit7 = db6:bit6 = db5:bit5 = db4 'HIGH NIBBLE data from lcd' pulse en:bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:en = 0 'LOW NIBBLE data from lcd' if bit8 then goto busy_flag_check_from_lcd 'bit 8 of data is the busy flag bit / 1 = lcd is busy / 0 = lcd is ready' return '*************************************************************************************************************************' #character_build 'generates characters in lcd ram from characterbuild table / 8 characters of 5X8 pixels' for adr = 0 to 63 'lcd display character generation (CG) address' looktab characterbuild, adr, dat 'lcd data for character generation' gosub data_to_CG_ram_lcd 'set character generation data in CG address' next return '*************************************************************************************************************************' ' (CG dat adr) 000/XXXXX first 3 bits are not used/ last 5 bits are for character generation ' table characterbuild &b00000100 '(0) 000/ 1 ' character build data for antenna symbol/ read from DD-ram address &h08' &b00001110 '(1) 000/ 111 ' *put&h08*' &b00011111 '(2) 000/11111' &b00000100 '(3) 000/ 1 ' &b00000100 '(4) 000/ 1 ' &b00000100 '(5) 000/ 1 ' &b00000100 '(6) 000/ 1 ' &b00000000 '(7) 000/ '-----------------------------------------' &b00000100 '(8) 000/ 1 ' character build data for heart/ read from DD-ram address &h09' &b00000100 '(9) 000/ 1 ' *put&h09*' &b00000100 '(10) 000/ 1 ' &b00000100 '(11) 000/ 1 ' &b00011111 '(12) 000/11111' &b00001110 '(13) 000/ 111 ' &b00000100 '(14) 000/ 1 ' &b00000000 '(15) 000/ '-----------------------------------------' &b00000000 '(16) 000/ ' character build data for happy/ read from DD-ram address &h0a' &b00000000 '(17) 000/ ' *put&h0a*' &b00001010 '(18) 000/ 1 1 ' &b00000000 '(19) 000/ ' &b00000100 '(20) 000/ 1 ' &b00010001 '(21) 000/1 1' &b00001110 '(22) 000/ 111 ' &b00000000 '(23) 000/ '-----------------------------------------' &b00011111 '(24) 000/11111 character build data for window/ read from DD-ram address &h0b' &b00010101 '(25) 000/1 1 1' *put&h0b*' &b00010101 '(26) 000/1 1 1' &b00011111 '(27) 000/11111' &b00010101 '(28) 000/1 1 1' &b00010101 '(29) 000/1 1 1' &b00011111 '(30) 000/11111' &b00011111 '(31) 000/11111'-----------------------------------------' &b00000000 '(32) 000/00000 empty place for character build data/ read from DD-ram address &h0c' &b00000000 '(33) 000/00000' *put&h0c*' &b00000000 '(34) 000/00000' &b00000000 '(35) 000/00000' &b00000000 '(36) 000/00000' &b00000000 '(37) 000/00000' &b00000000 '(38) 000/00000' &b00000000 '(39) 000/00000 -----------------------------------------' &b00000000 '(40) 000/00000 empty place for character build data/ read from DD-ram address &h0d' &b00000000 '(41) 000/00000' *put&h0d*' &b00000000 '(42) 000/00000' &b00000000 '(43) 000/00000' &b00000000 '(44) 000/00000' &b00000000 '(45) 000/00000' &b00000000 '(46) 000/00000' &b00000000 '(47) 000/00000 -----------------------------------------' &b00000000 '(48) 000/00000 empty place for character build data/ read from DD-ram address &h0e' &b00000000 '(49) 000/00000' *put&h0e*' &b00000000 '(50) 000/00000' &b00000000 '(51) 000/00000' &b00000000 '(52) 000/00000' &b00000000 '(53) 000/00000' &b00000000 '(54) 000/00000' &b00000000 '(55) 000/00000 -----------------------------------------' &b00000000 '(56) 000/00000 empty place for character build data/ read from DD-ram address &h0f' &b00000000 '(57) 000/00000' *put&h0f*' &b00000000 '(58) 000/00000' &b00000000 '(59) 000/00000' &b00000000 '(60) 000/00000' &b00000000 '(61) 000/00000' &b00000000 '(62) 000/00000' &b00000000 '(63) 000/00000 -----------------------------------------' tabend |
