Thanks for your help! Hi-Lo-active was exactly what I needed to know. I also found out that the CC1M1.1 FREQ2 can handle up to about 32 kHz and was wondering if this still is the case with the CC1M2.01? Yours truly, H.J. Windt > > rehi :-) > > > > the original manual says: > > the pins DCF/FRQ and FRQ1 are Hi-Lo-sensitive and able > > to count a rate of flanks from 100 to 30.000 per second. > > > bad thing.. that was from the CControl II manual - forget it! :-) > > CControl I can only count up to 5.000 Hz with an error less than 1 %. > higher frequencies are countable, but with a fast rising error. > > the "Ereigniszahlermode" allows you to count low frequencies or > simply events more exactly than the "Frequenzzahlermode" can. > the pins are Hi-Lo-active. |
