> rehi :-) > > the original manual says: > the pins DCF/FRQ and FRQ1 are Hi-Lo-sensitive and able > to count a rate of flanks from 100 to 30.000 per second. > bad thing.. that was from the CControl II manual - forget it! :-) CControl I can only count up to 5.000 Hz with an error less than 1 %. higher frequencies are countable, but with a fast rising error. the "Ereigniszahlermode" allows you to count low frequencies or simply events more exactly than the "Frequenzzahlermode" can. the pins are Hi-Lo-active. |
