 Re: 12 bits AD Wandler Kategorie: Programmierung Basic (von Hans - 13.02.2006 21:54)
 Als Antwort auf Re: 12 bits AD Wandler von Stefan Süßmann - 13.02.2006 19:41
Hans nutzt:  CC1-M-Unit V1.2/2.0
Thanks Stefan
But I don't understand it already
How do I get all 8 Ad variabele in 8 WORD's
And I only progr. conrad C-control/basic entwicklung
And I donÂ’t understand the command return zwischenwert
I hope that you can help me again
my used range is 0-5V for all AD inputs,
I go away for a few day so I cant react before fryday
Hans
> > Hallo
> > Thanks.
> > The Max 127 is a much better chip
> > But I donÂ’t understand anything of the 12C
> > Do you have a program for the Max127
> '------------------------------ function max127auslesen --------------------------------------------------------
> function Max127auslesen(chsetting as byte)
>          IIC.init
>          IIC.stop
>          IIC.start
>            IIC.send max127adresse
>            IIC.send chsetting
>          IIC.stop
>          IIC.start
>           IIC.send (max127adresse + 1)
>           IIC.get z1
>           IIC.get z2
>           z2 = z2 shr 4
>         IIC.stop
>       IIC.off
>     zwischenwert = ((z1*16) + z2)
>    return zwischenwert
> end function
> z1-z4 are bytes that i use global. max127adresse is the set adress of the max127 and chsetting sets the number of the AD-channel and the used range (0-5V, 0-10V,...shown in the datasheet).
> Stefan
Re: 12 bits AD Wandler (von Stefan Süßmann - 14.02.2006 9:54)
    Re: 12 bits AD Wandler (von Hans - 17.02.2006 20:47)
        Re: 12 bits AD Wandler (von Stefan Süßmann - 20.02.2006 8:35)
            Re: 12 bits AD Wandler (von Hans - 22.02.2006 20:21)
                Re: 12 bits AD Wandler (von Stefan Süßmann - 22.02.2006 22:41)
                    Re: 12 bits AD Wandler (von Hans - 23.02.2006 20:42)
                       Re: 12 bits AD Wandler (von Stefan Süßmann - 23.02.2006 22:05)
                          Re: 12 bits AD Wandler (von Hans - 25.02.2006 13:47)
                             Re: 12 bits AD Wandler (von Windt H.J. - 1.03.2006 23:12)
                                Re: 12 bits AD Wandler (von Hans - 4.03.2006 10:49)
                Re: 12 bits AD Wandler (von Stefan Süßmann - 22.02.2006 22:21)
            Re: 12 bits AD Wandler (von Hans - 22.02.2006 20:20)
Re: 12 bits AD Wandler (von Stefan Süßmann - 14.02.2006 9:50)
