> Oke Stefan > > thanks for your patient > I understand finely the channel selection > Can you also explain MAX127adres (you say 80 decimal &h50 ???) A Max127 has a adress 0101 A2 A1 A0 RW 01010000 = 80 01010010 = 82 01010100 = 84 01011000 = 88 ..and some more. You can use 8 Max127 on one i2c-bus. The begining 0101 is fixed and 01010000 = 80 dez. > I cant find it . > I understand Max127 adres+1 (write and +1 is read) > > And now my biggest problem > I cant order the MAX127 in the Netherlands > Conrad.nl, Farnell. Dil, Display electronics, they dont have it > I can order the MAX127, but than I have to order so much that the amount will be 350 euro > That is to much for me I had that problem too. You can order two samples for free at the maxim-hp. You just have to answer o lot of questions like "do you want to use them for nuklear weapons?........" > So now I have almost a good program but I cant order the MAX127 > > ,New Progr. 4 AD in > > DEFINE Var1 BYTE[1] > DEFINE Var2 BYTE[2] > DEFINE AD1 WORD[2] > DEFINE AD2 WORD[3] > DEFINE AD3 WORD[4] > DEFINE AD4 WORD[5] > > DEFINE Max127adres &h90 'Is still wrong > > > #Start > GOSUB programma > PRINT"#ON_LCD#"; > PRINT"#L101#"; > PRINT"1=";AD1; > PRINT"#L109#"; > PRINT"2=";AD2; > PRINT"#L201#"; > PRINT"3=";AD3; > PRINT"#L209#"; > PRINT"4=";AD4; > PRINT"#OFF#"; > GOTO Start > > > #Programma > PRINT"#ON_IIC#"; PRINT"#STOP#"; <------------------- was missing, but i´m not sure if necessary > PRINT"#START#"; > PUT Max127adres > PUT &B10000000 'CHannel 1 This is Ch.0, 0-5V, normel operation > PRINT"#STOP#"; > > PRINT"#START#"; > PRINT Max127adres+1 > GET Var1 > GET Var2 > Var2 = Var2 SHR 4 > PRINT"#STOP#"; > PRINT"#OFF#"; > AD1 = ((Var1*16) + Var2) > > PRINT"#ON_IIC#"; > PRINT"#START#"; > PUT Max127adres > PUT &B10010000 'CHannel 2 This ist Channel 1 > PRINT"#STOP#"; > > PRINT"#START#"; > PRINT Max127adres+1 > GET Var1 > GET Var2 > Var2 = Var2 SHR 4 > PRINT"#STOP#"; > PRINT"#OFF#"; > AD2 = ((Var1*16) + Var2) > > PRINT"#ON_IIC#"; > PRINT"#START#"; > PUT Max127adres > PUT &B10110000 'CHannel 3 OK, Ch.3 > PRINT"#STOP#"; > > PRINT"#START#"; > PRINT Max127adres+1 > GET Var1 > GET Var2 > Var2 = Var2 SHR 4 > PRINT"#STOP#"; > PRINT"#OFF#"; > AD3 = ((Var1*16) + Var2) > > PRINT"#ON_IIC#"; > PRINT"#START#"; > PUT Max127adres > PUT &B11000000 'CHannel 4 OK. Ch.4 > PRINT"#STOP#"; > > PRINT"#START#"; > PRINT Max127adres+1 > GET Var1 > GET Var2 > Var2 = Var2 SHR 4 > PRINT"#STOP#"; > PRINT"#OFF#"; > AD4 = ((Var1*16) + Var2) > RETURN > Bye Stefan |
