 Re: Pressure sensor 4-20 mA Kategorie: Programmierung Basic (von Hans - 10.02.2006 18:21)
 Als Antwort auf Re: Pressure sensor 4-20 mA von Hans - 10.02.2006 16:04
Hans nutzt:  CC1-M-Unit V1.2/2.0
Hallo
I found a very interesting site
About a 12 bits AD converter
http://cubloc.com/download/app_mcp3202.pdf
But is there some one  who can translate the basic in the Munit 2 basic
Hans
> I thought off a 10BITS chip  AD9051    in 0-5 volt
> 10 bits parallel out.
> All the 10 outÂ’s  into the 16 channel multiplexer MC 14067B
> And via een BCD code out the Munit
> ComeÂ’s the VAR  into port5 of  the Munit
> See example
> DEFINE Ingang9       BIT[1]         'Ingangen zo geplaats dat ze netjes op en rij staan in 1 WORD
> DEFINE Ingang10      BIT[2]
> DEFINE Ingang1       BIT[9]
> DEFINE Ingang2       BIT[10]
> DEFINE Ingang3       BIT[11]
> DEFINE Ingang4       BIT[12]
> DEFINE Ingang5       BIT[13]
> DEFINE Ingang6       BIT[14]
> DEFINE Ingang7       BIT[15]
> DEFINE Ingang8       BIT[16]
> DEFINE SensorValue   WORD[1]
> define I            byte[4]
> DEFINE Ieen         BIT[25]
> DEFINE Itwee        BIT[26]
> DEFINE Idrie        BIT[27]
> DEFINE Ivier        BIT[28]
> DEFINE InVar        BIT[17]
> DEFINE poortA       Port[1]
> DEFINE poortB       Port[2]
> DEFINE poortC       Port[3]
> DEFINE poortD       Port[4]
> DEFINE Bit10In      PORT[5]
> #Start
> #Ingangen
>  FOR I=0 to 9
>  PoortA=Ieen   'BCD code voor chip MC 14067B
>  PoortB=Itwee
>  PoortC=Idrie
>  PoortD=Ivier
>  IF Bit10In=ON THEN InVar=ON ELSE InVar=OFF
>  IF I = 0 THEN Ingang1 = InVar
>  IF I = 1 THEN Ingang2 = InVar
>  IF I = 2 THEN Ingang3 = InVar
>  IF I = 3 THEN Ingang4 = InVar
>  IF I = 4 THEN Ingang5 = InVar
>  IF I = 5 THEN Ingang6 = InVar
>  IF I = 6 THEN Ingang7 = InVar
>  IF I = 7 THEN Ingang8 = InVar
>  IF I = 8 THEN Ingang9 = InVar
>  IF I = 9 THEN Ingang10 = InVar
> Next
> 'Example pressurre of 250 bar
> 'totaal 1023 steps
> IF SensorValue > 204 THEN SensorValue = SensorValue - 204 ELSE SensorValue = 0  '1023/5=204 steps
> SensorValue = SensorValue * 250 / 819          '1023-204
> Goto Start
> But isnÂ’t there an easyer way
> Hans
> > Hallo
> > I have one more problem ,
> > IÂ’ve a pressure  sensor 4 to 20 mA
> > This  go on 250 ohm.
> > So I have 1 to 5 volt on the 8 bit A/D entrence.
> > 1 volt is 1/5  from the A/D port.
> > At the formule as, for example, the pressure sensor is  0 to 250 bar
> > IF Adport1>51 THEN Sensor1=Adport1-51 ELSE Sensor1=0
> > Sensor1=Sensor1*(250/204)
> > This is working
> > But itÂ’s to grove
> > The next question is:
> > Is there a way , or a chip,  bijv.  10 bits AD ingang
> > Hans
