 Re: Pressure sensor 4-20 mA Kategorie: Programmierung Basic (von Hans - 10.02.2006 16:04)
 Als Antwort auf Pressure sensor 4-20 mA von Hans - 9.02.2006 21:36
Hans nutzt:  CC1-M-Unit V1.2/2.0
I thought off a 10BITS chip  AD9051    in 0-5 volt
10 bits parallel out.
All the 10 outÂ’s  into the 16 channel multiplexer MC 14067B
And via een BCD code out the Munit
ComeÂ’s the VAR  into port5 of  the Munit
See example
DEFINE Ingang9       BIT[1]         'Ingangen zo geplaats dat ze netjes op en rij staan in 1 WORD
DEFINE Ingang10      BIT[2]
DEFINE Ingang1       BIT[9]
DEFINE Ingang2       BIT[10]
DEFINE Ingang3       BIT[11]
DEFINE Ingang4       BIT[12]
DEFINE Ingang5       BIT[13]
DEFINE Ingang6       BIT[14]
DEFINE Ingang7       BIT[15]
DEFINE Ingang8       BIT[16]
DEFINE SensorValue   WORD[1]
define I            byte[4]
DEFINE Ieen         BIT[25]
DEFINE Itwee        BIT[26]
DEFINE Idrie        BIT[27]
DEFINE Ivier        BIT[28]
DEFINE InVar        BIT[17]
DEFINE poortA       Port[1]
DEFINE poortB       Port[2]
DEFINE poortC       Port[3]
DEFINE poortD       Port[4]
DEFINE Bit10In      PORT[5]
#Start
#Ingangen
 FOR I=0 to 9
 PoortA=Ieen   'BCD code voor chip MC 14067B
 PoortB=Itwee
 PoortC=Idrie
 PoortD=Ivier
 IF Bit10In=ON THEN InVar=ON ELSE InVar=OFF
 IF I = 0 THEN Ingang1 = InVar
 IF I = 1 THEN Ingang2 = InVar
 IF I = 2 THEN Ingang3 = InVar
 IF I = 3 THEN Ingang4 = InVar
 IF I = 4 THEN Ingang5 = InVar
 IF I = 5 THEN Ingang6 = InVar
 IF I = 6 THEN Ingang7 = InVar
 IF I = 7 THEN Ingang8 = InVar
 IF I = 8 THEN Ingang9 = InVar
 IF I = 9 THEN Ingang10 = InVar
Next
'Example pressurre of 250 bar
'totaal 1023 steps
IF SensorValue > 204 THEN SensorValue = SensorValue - 204 ELSE SensorValue = 0  '1023/5=204 steps
SensorValue = SensorValue * 250 / 819          '1023-204
Goto Start
But isnÂ’t there an easyer way
Hans
> Hallo
> I have one more problem ,
> IÂ’ve a pressure  sensor 4 to 20 mA
> This  go on 250 ohm.
> So I have 1 to 5 volt on the 8 bit A/D entrence.
> 1 volt is 1/5  from the A/D port.
> At the formule as, for example, the pressure sensor is  0 to 250 bar
> IF Adport1>51 THEN Sensor1=Adport1-51 ELSE Sensor1=0
> Sensor1=Sensor1*(250/204)
> This is working
> But itÂ’s to grove
> The next question is:
> Is there a way , or a chip,  bijv.  10 bits AD ingang
> Hans
Re: Pressure sensor 4-20 mA (von Hans - 10.02.2006 18:21)
