do you have a seriell or a iic bus Avisaro Compact Flash Modul ? klaus > Here the results of the CF card > The module was indeed brooken > I have had a new one from Avisaro > And I have concted the Munit 2 with the program thad was made by mr.Windt > It works great > It also write date time and data in a tekst file wich you can import in Exel > So Mr Windt thank you again for it all > And I am going to try the iic. > > '****************** SETUP ******************' > pause 200 > 'put 0 > print"at+create test.txt" 'Create test.txt' > pause 150 > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"at+close" > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > '*******************************************' > '***************** PROGRAM *****************' > #start > print"at+append test.txt" 'Open test.txt for appending data' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"at+datastream" 'Type of data is datastream' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"The quick brown fox jumps over the lazy dog." 'datastream' > print"The Avisaro Compact Flash Box is GREAT!" 'datastream' > print"Testend?" 'datastream' > pause 50 : print"+" : pause 50 : print"+" : pause 50 : print"+" 'Stop writing data to test.txt' > pause 50 > #end_loop > beep 4,2,4: beep 4,2,4 > goto end_loop |
