> In my system I am trying to send a byte to a computer, using the serial port and PUT command but, to my surprise, I receive only 7 bits, not the higher one (for example, if I send 192 -11000000b- I receive 64 -1000000-). Does someone know where can be the problem? Is there something in the configuration I should take care of? This is most likely a problem on the PC side. Probably either your receiving program or the settings of the serial PC port are faulty (given that you really send 192). Bye Achim |
