 Re: opening serial port Kategorie: C-Control I V1.1 (von Thomas Wulf - 9.12.2005 11:15)
 Als Antwort auf opening serial port von Noel Ortiz - 9.12.2005 10:10
Thomas Wulf nutzt:  CC1-Unit V1.1, CC1-M-Unit V1.1, CC1-M-Unit V1.2/2.0, Micro, Open-Micro, Open-Mini
> Hello,
> Just a dumb question: using CControl M-Unit 2.0, is necessary to initialise the serial port? Can I just use "put" and "get" commands without opening it? By the way, is the command READSERIAL available for this version of the M-Unit?
> Thank you very much in advance.
> Noel
> Hello Noel,
you don ´t need to initialise the serial port. I think that the READSERIAL is not available.
You can use the IF RXD basic commando to check currently received data in the receiver buffer.
Best regards,
Thomas
