I forgot something, here is a better version. 'Stuuring voor de MC14067B een 16 channel Analoge multiplexer 'poort DEFINE ADin AD[1] define poort1 port[1] define poort2 port[2] define poort3 port[3] define poort4 port[4] 'VAR DEFINE I BYTE[1] DEFINE Ieen BIT[1] DEFINE Itwee BIT[2] DEFINE Idrie BIT[3] DEFINE Ivier BIT[4] define temp bit[16] define ingang1 bit[17] define ingang2 bit[18] define ingang3 bit[19] define ingang4 bit[20] define ingang5 bit[21] define ingang6 bit[22] define ingang7 bit[23] define ingang8 bit[24] define ingang9 bit[25] define ingang10 bit[26] define ingang11 bit[27] define ingang12 bit[28] define ingang13 bit[29] define ingang14 bit[30] define ingang15 bit[31] FOR I=0 to 15 Poort1=Ieen Poort2=Itwee Poort3=Idrie Poort4=Ivier if adin < 140 then temp = on else if adin > 240 then temp = off else goto pass if I = 0 then Ingang1 = temp if I = 1 then Ingang2 = temp if I = 2 then Ingang3 = temp if I = 3 then Ingang4 = temp if I = 4 then Ingang5 = temp if I = 5 then Ingang6 = temp if I = 6 then Ingang7 = temp if I = 7 then Ingang8 = temp if I = 8 then Ingang9 = temp if I = 9 then Ingang10 = temp if I = 10 then Ingang11 = temp if I = 11 then Ingang12 = temp if I = 11 then Ingang13 = temp if I = 11 then Ingang14 = temp if I = 11 then Ingang15 = temp #pass next |
