 Re: write smaller You can Kategorie: Programmierung Basic (von Stefan Tappertzhofen, Homepage - 17.09.2005 15:26)
 Als Antwort auf write smaller You can von Hans - 17.09.2005 14:37
Stefan Tappertzhofen nutzt:  CC1-M-Unit V1.2/2.0, Micro
> How can I this example smaller write
> in advance warm thanks
Hello,
maybe you try it that way (in BASIC++ or a few modifications in CCBASIC):
'Stuuring voor de MC14067B een 16 channel Analoge multiplexer
'poort
DEFINE ADin     AD[1]
define poort1    port[1]
define poort2    port[2]
define poort3    port[3]
define poort4    port[4]
'VAR
DEFINE I        BYTE[1]
DEFINE Ieen     BIT[1]
DEFINE Itwee    BIT[2]
DEFINE Idrie    BIT[3]
DEFINE Ivier    BIT[4]
define ingang1  bit[17]
define ingang2  bit[18]
define ingang3  bit[19]
define ingang4  bit[20]
define ingang5  bit[21]
define ingang6  bit[22]
define ingang7  bit[23]
define ingang8  bit[24]
define ingang9  bit[25]
define ingang10  bit[26]
define ingang11  bit[27]
define ingang12  bit[28]
define ingang13  bit[29]
define ingang14  bit[30]
define ingang15  bit[31]
define temp as bit[32]
for i = 0 to 15
    poort1 = ieen
    poort2 = itwee
    poort3 = idrie
    poort4 = ivier
    IF ADin<140 THEN
        temp=ON
    ELSE
        IF ADin>240 THEN
            temp=OFF
        ELSE
            goto resm
        END IF
    END IF
    select case i
        case 0
            ingang1 = temp
        case 1
            ingang2 = temp
        case 2
            ingang3 = temp
        case 3
            ingang4 = temp
        case 4
            ingang5 = temp
        case 5
            ingang6 = temp
        case 6
            ingang7 = temp
        case 7
            ingang8 = temp
        case 8
            ingang9 = temp
        case 9
            ingang10 = temp
        case 10
            ingang11 = temp
        case 11
            ingang12 = temp
            ingang13 = temp
            ingang14 = temp
            ingang15 = temp
    end select
    #resm
next i
Greetings,
Stefan
Meine Homepage: http://www.fdos.de
Re: write smaller You can (von Hans - 17.09.2005 18:15)
    Re: write smaller You can (von Stefan Tappertzhofen - 17.09.2005 18:21)
