 Re: RN-Motor an I2C-Bus Kategorie: C-Control I V1.2/2.0 (von Gaston - 2.07.2005 10:49)
 Als Antwort auf Re: RN-Motor an I2C-Bus von Windt H.J. - 1.07.2005 19:48
Gaston nutzt:  CC1-M-Unit V1.2/2.0
Hello,
thank you for your answer.
Unfortunately I have no application board and no lcd display.
Greetings
Gaston
> Hello,
> Sorry I am writing this in English.
> Would you like to try something?
> Connect the sda line from your motor controller to port 4 and the scl line to port 5 of the c-control I v2.0 and load and run the program below.
> Please let me know what the lcd displays.
> Greetings,
> H.J. Windt
> '*                         WINDT SYSTEMS                             *'
> '* DEVICE SEEK FOR EMULATED I2C BUS v1.2 for CCIUM2.01 with CCIAB2.0 *'
> '*                           H.J. WINDT                              *'
> '*                             2004                                  *'
> 'This software, with the C-Control I Unit M2.01 mounted on the C-Control I Application Board 2.0,'
> 'will search the emulated I2C bus for any I2C devices and display the address on the LCD'
> 'of any found I2C device.'
> 'The emulated SDA line is via port 4.'
> 'The emulated SCL line is via port 5.'
> 'Feel free to use and share this software!'
> '*************** INS and OUTS **************'
> define sda port[4]
> define scl port[5]
> define lcd_backlight_off port[16]
> '**************** VARIABLES ****************'
> define i2c_nack bit[1]
> define i2c_last bit[2]
> define i2c_nack_count byte[2]
> define i2c_byte byte[3]
> define i2c_out_bit bit[24]
> define i2c_in_bit bit[17]
> define loop byte[4]
> define address byte[5]
> '**************** CONSTANTS ****************'
> '****************** SETUP ******************'
> print"#ON_CONFIG#"; : put &b1000 : print"#OFF#"; 'activate pullup resistors byteport 1'
> lcd_backlight_off = 0
> print"#ON_LCD#";:print"#INIT#";:print"#CLR#";
> print" WINDT SYSTEMS";
> print"#L201#";
> print"EI2C DEVICE SEEK";
> pause 150
> '***************** PROGRAM *****************'
> #start
> print"#CLR#";
> for address = 0 to 254 step 2
> print"#L101#";
> print"EI2C Search ADR=";
> print"#L206#";
> print "&d";address;
> #try_i2c_again
> gosub start_i2c
> i2c_byte = address : gosub write_byte_i2c
> gosub stop_i2c
> if i2c_nack_count > 0 and i2c_nack_count < 4 then goto try_i2c_again
> if not i2c_nack then gosub print_i2c_device_address
> next
> print"#CLR#";
> print"#L106#";
> print"DONE!!";
> pause 150
> print"#CLR#";
> lcd_backlight_off = 1
> print"#OFF#";
> end
> '*************** SUBROUTINES ***************'
> #print_i2c_device_address
> beep 4,2,4: beep 4,2,4
> print"#CLR#";
> print"#L103#";
> print"EI2C Device!";
> print"#L201#";
> print"Address = &d";
> print address;
> pause 300
> print"#CLR#";
> return
> #start_i2c
> sda = 0 : scl = 0
> return
> #stop_i2c
> sda = 0 : deact scl : deact sda
> return
> #write_byte_i2c
> for loop = 1 to 8
> sda = i2c_out_bit
> deact scl
> #write_byte_i2c_clock_stretch
> if not scl then goto write_byte_i2c_clock_stretch
> scl = 0
> i2c_byte = i2c_byte shl 1
> next
> deact sda
> deact scl
> #write_byte_i2c_ack_clock_stretch
> if not scl then goto write_byte_i2c_ack_clock_stretch
> i2c_nack = sda
> scl = 0
> if i2c_nack then goto i2c_error
> i2c_nack_count = 0
> return
> #i2c_error
> i2c_nack_count = i2c_nack_count + 1
> goto stop_i2c
> '******* INITIALIZATION SUBROUTINES ********'
> '****************** DATA *******************'
> > Hallo,
> > ich versuche seit Tagen die Schrittmotorsteuerung RN-Motor über den I2C-Bus einer C-Control-1 M-Unit V2.0 anzusteuern und bekomme es einfach nicht hin. Hat vielleicht jemand das Problem schon gelöst und wäre bereit mich vor der Verzweiflung zu retten?
> > Vielen Dank im Voraus für die Hilfe
Re: RN-Motor an I2C-Bus (von Henrik - 2.07.2005 11:53)
    Re: RN-Motor an I2C-Bus (von Gaston - 3.07.2005 10:38)
