 Problem mit i2c-Bus Routine Kategorie: Programmierung Basic (von Rille - 19.06.2005 23:12)
Rille nutzt:  CC1-Unit V1.1
Hallo an Alle,
ich habe das Problem eine Routine für den Motortreiber "RN-Motor i2c" zu schreiben.
Seit mehreren Tagen versuche ich das Ding zum laufen zu bringen.
Bitte !!! kann mir Jemand sagen was ich da falsch mache.
Am Besten währe es, wenn ich ein Programmbeispiel bekommen könnte.
Danke  Rille
define sda port[1]
define scl port[2]
define daten byte
define n byte
sda = on
scl = on
gosub start
daten = &H56
gosub i2c_write
daten = 10        'kennung
gosub i2c_write
daten = 1         'befehlscod
gosub i2c_write
daten = 2         'motor
gosub i2c_write
daten = 50
gosub i2c_write
daten = 0
gosub i2c_write
gosub stop
gosub start
daten = &H56
gosub i2c_write
daten = 10        'kennung
gosub i2c_write
daten = 14        'befehlscod
gosub i2c_write
daten = 0         'motor
gosub i2c_write
daten = 0
gosub i2c_write
daten = 0
gosub i2c_write
gosub stop
gosub start
daten = &H56
gosub i2c_write
daten = 10        'kennung
gosub i2c_write
daten = 4         'befehlscod
gosub i2c_write
daten = 2         'motor
gosub i2c_write
daten = 1
gosub i2c_write
daten = 0
gosub i2c_write
gosub stop
gosub start
daten = &H56
gosub i2c_write
daten = 10        'kennung
gosub i2c_write
daten = 8         'befehlscod
gosub i2c_write
daten = 2         'motor
gosub i2c_write
daten = 100
gosub i2c_write
daten = 0
gosub i2c_write
gosub stop
gosub start
daten = &H56
gosub i2c_write
daten = 10        'kennung
gosub i2c_write
daten = 6         'befehlscod
gosub i2c_write
daten = 2         'motor
gosub i2c_write
daten = 0
gosub i2c_write
daten = 0
gosub i2c_write
gosub stop
end
#i2c_write
for n = 1 to 8
sda = off
if (daten and 128) = 128 then sda = on
pulse scl
daten = daten shl 1
next
pulse scl
return
#start
sda = off
scl = off
return
#stop
sda = off
scl = on
sda = on
return
Re: Problem mit i2c-Bus Routine (von Windt H.J. - 22.06.2005 17:11)
Re: Problem mit i2c-Bus Routine (von Carsten - 20.06.2005 9:54)
