 Re: PC - CControl M Unit Kategorie: C-Control I V1.1 (von Carsten - 14.06.2005 10:26)
 Als Antwort auf PC - CControl M Unit von Branek - 7.06.2005 19:43
Carsten nutzt:  CC1-M-Unit V1.2/2.0
Hi Branko,
As i read and understood the ProfiLab Expert 3.0 description, it is thought to be used with it's "own" hardware components (see http://www.pci-card.com/lieferp1.htm).
So if you replace the CControl Unit with a fitting component - you should be able to control AND visualize the process with a PC and ProfiLab Expert 3.0.
If you only want to monitor the processes that are controlled by the CControl, you may leave the C-Control and just measure and display values from the hardware, without using the C-Control. If you want to use the C-Control to send data, you would need to replace teh program on the C-Control and also need support from ProfiLab - that is surely hardest to do or impossible if ProfiLab-Makers may not want that you use other than their hardware - just ask them.
Greetings Carsten
> Hi all.
>  I am relativly new to working with CC unit and I hope that someone could help me out. I need to make a visual interface for controlling a certain process that is controlled by CC. I chose ProfiLab Expert 3.0 as It fits me perfectly for this job. However, I am pretty clueless as to how to make the CC Unit and ProfiLab interact with each other. I allready have a fully working program, a complete controll box, and all I need is to make it controllable from a PC with a graphical interface. If anyone could help me out with this or point me in the right direction, I would be most thankfull.
> P.S.
> I am sorry for this post in English but my Deutsch is much worse than my English and I hope that you don't mind me posting in it.
> Best regards
> Branko
