 Re: C-Control-Pro - Die neue C-Control-Familie Kategorie: Verschiedenes (von Guido - 31.01.2005 8:53)
 Als Antwort auf Re: C-Control-Pro - Die neue C-Control-Familie von Dietmar - 29.01.2005 22:38
Hallo Dietmar,
geht schon ;-)
Rem A real-time scheduling excercition for upgrading BASCOM to real-real time.
Rem *************************************************************************
Rem 18 september 2000, the birth, by ceasarean, of Bascom multitasking.
Rem Keep it SIMMple, non-preemptive
Const Nbr_tasks = 4                       'Looks enough for now
Dim Task_resume_1(nbr_tasks) As Byte      'save resume address here
Dim Task_resume_2(nbr_tasks) As Byte      'save resume address here
Dim Task_status(nbr_tasks) As Byte        'status of task/metaphore's
Dim Current_task As Byte                  'Task that is active
Dim Work_byte As Byte
Dim Example As Byte
Dim T3count As Byte
Dim T4count As Byte
'( What is it, well a table of resume addresses and a status byte indicating if
Resume Is Wanted Or Indicating What The Task Is Waiting For (reason For Suspend)
In fact thats all.
Metaphores Can Be Manipulated By Other Tasks Or From Interrupt Routines.
Metaphores And Sram Are Absolutely Not Protected Against Access , So Know
What You Are Doing.
Task Are Scheduled Robin Around (1 , 2 , 3 , 4 , 1 , 2 , 3 , 4 , 1 , 2 , 3.etc)
Other Policies Are Possible , Give Task 1 Priority (1 , 2 , 1 , 3 , 1 Etc)
Note That In This Case The Minimal Examples Given In The Tasks Do Not Work,
So Becarefull When Fiddling Around With These Things.
As The Tasks Have No Private Stack Space (would Be Nice , But Little Resources),
Suspension Always Has To Be Initiated When Stack Is Not In Use (so To Be
Concrete , No Suspend Invocation In A Subroutine).
Init_task_list:
Rem Init resume addresses, challenge : how to get them. Answer : Play Dirty
Rem The task address is revealed by the gosub, which pushes the resume address
Rem on the stack. We pop it up and save it.It does not win a beaty contest,but.
'Iniialization of task start addresses---------------------------------------
Goto Task1                                'task 1 will direct issue a gosub
'                                          to init_task_1, revealing resume
'                                          address
Init_task_1:                              'Invoked as gosub, but never returns !
$asm
pop R16
sts {work_byte},r16
$end Asm
Task_resume_1(1) = Work_byte              'store first pop
$asm
pop R16
sts {work_byte},R16
$end Asm
Task_resume_2(1) = Work_byte              'store second pop
Task_status(1) = 0                        'Not suspended
Rem                                       'End NEVER return, stack clean !
Goto Task2
Init_task_2:
$asm
pop R16
sts {work_byte},r16
$end Asm
Task_resume_1(2) = Work_byte              'store first pop
$asm
pop R16
sts {work_byte},R16
$end Asm
Task_resume_2(2) = Work_byte              'store second pop
Task_status(2) = 0                        'Not suspended
Goto Task3
Init_task_3:
$asm
pop R16
sts {work_byte},r16
$end Asm
Task_resume_1(3) = Work_byte              'store first pop
$asm
pop R16
sts {work_byte},R16
$end Asm
Task_resume_2(3) = Work_byte              'store second pop
Task_status(3) = 0                        'Not suspended
Goto Task4
Init_task_4:
$asm
pop R16
sts {work_byte},r16
$end Asm
Task_resume_1(4) = Work_byte              'store first pop
$asm
pop R16
sts {work_byte},R16
$end Asm
Task_resume_2(4) = Work_byte              'store second pop
Task_status(4) = 0                        'Not suspended
Rem                                       'End  fall through to scheduler
'Here the scheduler starts.
Scheduler:                                'Work assigner
For Current_task = 1 To Nbr_tasks         'Cycle through robin around fashion
If Task_status(current_task) <> 0 Then    'Waiting for something ?
Goto Scheduler_next                       'YES, waiting for something
Else                                      'Prepare Return = resume address
Work_byte = Task_resume_2(current_task)   'Look sharp, reverse order
$asm
lds r16,{work_byte}
push r16
$end Asm
Work_byte = Task_resume_1(current_task)   'Look sharp, reverse order
$asm
lds r16,{work_byte}
push r16
$end Asm
End If                                    'Simmple
Return                                    'Crazy code isn't it ?
'....................back after task initiated suspension....................
'Assume (or beware) that current_task is untouched .
Task_suspend:                             'Entered by a GOSUB !
$asm
pop r16
sts {work_byte},R16
$end Asm
Task_resume_1(current_task) = Work_byte   'store first pop
$asm
pop R16
sts {work_byte},r16
$end Asm
Task_resume_2(current_task) = Work_byte   'store second pop
'                                         Thats all, folks
Scheduler_next:
Next Current_task                         'Check next task
Goto Scheduler                            'ad infinitum
'( When a task thinks there is nothing to do, it suspends itself . It calls
This Routine By Gosub , That Means The Resume Address Is On Stack. This Address
Is Saved. The Task Identifier Is Act_task. Initially Straigth Forward
Implemented Without Any Sophistication.
Rem **************************Task 1*****************************************
Task1:                                    'Entrypoint task 1 for setup
Gosub Init_task_1                         'use this label only in setup
Task1_loop:                               'Real start task 1
'Do something
Example = Example + 1                     'Whatever
'And give other tasks a chance (non pre-emptive system, so necessary)
Gosub Task_suspend                        'Temporarely goodbye
'Do again something
Task_status(4) = 1                        'stop task 4 (status not 0!)
Goto Task1_loop
Rem **************************Task 2*****************************************
Task2:                                    'Entrypoint task 1 for setup
Gosub Init_task_2                         'use this label only in setup
Task2_loop:                               'Real start task 1
'Do something
Testcondition:
If Example <> 1 Then
   Gosub Task_suspend                        'Wait for example to become 1
   Goto Testcondition                        'RTOS does not save processor status
   Rem                                       'bits
Else
   Task_status(4) = 0                        'task2:task4 runs 255;1 (if1,2,3,4!)
   Gosub Task_suspend                        'give 4 a chance to run
End If
Goto Task2_loop
Rem ******************************task 3 ************************************
Task3:                                    'Entrypoint task 3
Gosub Init_task_3
Task3_loop:                               'Real start task 3
T3count = T3count + 1
Goto Task3_loop
Rem *****************************   task 4    *******************************
Task4:                                    'Entrypoint task 4
Gosub Init_task_4
Task4_loop:                               'Real start task 4
T4count = T4count + 1
Example = 250                             't2:t4 now 6:1
Goto Task4_loop
End
> Hallo Gerhard,
> > Ich meine, dann kann man doch gleich auf die Atmelschiene umsteigen.
> das ist nicht gesagt. In diesem Fall muß man sich auch den BASCOM-BASIC-Compiler zulegen und der ist auch nicht gerade preiswert. Der BASCOM erzeugt sicher schnelleren Code als das (sehr wahrscheinlich) interpretierte C und BASIC der Pro-Controller, aber bietet systembedingt kein Multithreading.
> Ob die Pro-Version breite Akzeptanz finden wird, hängt in erster Linie von der Qualität der zur Verfügung gestellten Programmiersprachen und einem weitgehend fehlerfreien Betriebssystem ab. Außerdem hoffe ich, Conrad hat etwas aus der mißglückten Markteinführung der CC1-V2 und Micro gelernt.
> Gruß, Dietmar
Re: C-Control-Pro - Die neue C-Control-Familie (von Dietmar - 5.02.2005 12:32)
