'I detected a small bug that the compiler missed, but even with the bug, the program worked perfectly,' 'I do not understand this, but anywayÂ…Â… here is the new version!' 'This version even uses less basic bytes, always a good thing!!' 'The bug I detected was in the gosubroutine: #data_from_CG_ram_lcd.' 'At the bottom of the gosubroutine a goto command_to_lcd was placed where command_to_lcd was and' 'a return was deleted.' '-------------------------------------------------------------------------------------------------------------------------' ' *************************************************************************************************' ' * WINDT SYSTEMS *' ' * LCD Possibility Examples v1.31 For The C-Control 1 Unit M2.01 *' ' * H.J. WINDT *' ' * 2004 *' ' *************************************************************************************************' '-------------------------------------------------------------------------------------------------------------------------' 'This program shows the possibilities of the lcd display which are not used in ccbasic 2.0.' 'The possibilities include reverse printing on lcd, 3 different cursors, cursor shifting, character generation AND display ON-' 'on/ off' 'NEW----->> SCROLL DOWN AND SCROLL UP' 'Character generation is the possibility to design your own 8 characters.' 'Feel free to use and share this software in any way you want!' '****************************************************** IN and OUTS ******************************************************' '-----port 2 lcd connections-----' define db4 port[9] 'databus 4' define db5 port[10] 'databus 5' define db6 port[11] 'databus 6' define db7 port[12] 'databus 7' define rw port[13] '0 = write to lcd display / 1 = read from lcd display' define rs port[14] '0 = command / 1 = data' define en port[15] '1 to 0 = enable' define lcd_light_off port[16] '(off)0 = light on / (on)1 = light off' '******************************************************* VARIABLES *******************************************************' define data byte[1]'data / used for translating byte into bits and vice versa for I/O of port 2 (lcd port), -' define bit1 bit[1] '- needed because of a bug in the CC1 M2.01 system' define bit2 bit[2] define bit3 bit[3] define bit4 bit[4] define bit5 bit[5] define bit6 bit[6] define bit7 bit[7] define bit8 bit[8] '-----------------------------------------------------------------------------------------' define adr byte[2] 'address code' define cmd byte[3] 'command code' define dat byte[4] 'data code' define dat2 byte[5] define loop byte[6] '******************************************************** SET UP *********************************************************' gosub initialize_lcd beep 4,2,4 beep 4,2,4 '*************************************************************************************************************************' lcd_light_off = 0 #start print"#ON_LCD#"; print"#CLR#"; 'scroll down' print"#L101#"; print" SCROLL DOWN"; gosub scroll_down print"#CLR#"; 'scroll up' print"#L201#"; print" SCROLL UP"; gosub scroll_up print"#CLR#"; 'forward and reverse printing on lcd' gosub entry_mode_set_left_to_right print"#L101#"; print"Entry Mode LR"; gosub entry_mode_set_right_to_left print"#L216#"; print"Entry Mode RL"; gosub entry_mode_set_left_to_right pause 200 for loop = 0 to 3 'no cursor and 3 different cursors' print"#CLR#"; print"Cursor "; print loop; print" "; on loop gosub lcd_cursor_0, lcd_cursor_1, lcd_cursor_2, lcd_cursor_3 pause 200 next print"#CLR#"; print"Cursor Movement"; 'moving the cursor left and right' for loop = 1 to 15 pause 25 gosub lcd_cursor_shift_left next for loop = 1 to 15 pause 25 gosub lcd_cursor_shift_right next pause 25 gosub lcd_cursor_0 print"#CLR#"; print"Generated Chara."; 'printing 4 example generated characters on the lcd' print"#L205#"; put&h08 'antenna' print" "; put&h09 'heart' print" "; put&h0a 'happy' print" "; put&h0b 'window' pause 200 print"#CLR#"; print" DiSpLaY "; 'display off on off on ......' print"#L201#"; print" ON/OFF "; for loop = 1 to 10 pause 25 gosub display_off pause 25 gosub display_on_0 next print"#OFF#"; tog lcd_light_off goto start '*************************************************************************************************************************' #scroll_down 'shifts characters on top row to bottom row of lcd display' FOR LOOP = 0 TO 15 pause 25 '******delete this line for speed******' adr = loop : gosub data_from_DD_ram_lcd dat2 = dat dat = &h20 : gosub data_to_DD_ram_lcd dat = dat2 adr = adr + 64 : gosub data_to_DD_ram_lcd next pause 25 '******delete this line for speed******' return #scroll_up 'shifts characters on bottom row to top row of lcd display' for loop = 64 to 79 pause 25 '******delete this line for speed******' adr = loop : gosub data_from_DD_ram_lcd dat2 = dat dat = &h20 : gosub data_to_DD_ram_lcd dat = dat2 adr = adr - 64 : gosub data_to_DD_ram_lcd next pause 25 '******delete this line for speed******' return #display_off 'lcd display OFF/ cursor OFF / understripe OFF' cmd = &b00001000:goto command_to_lcd #display_on_0 'lcd display ON and' #lcd_cursor_0 'cursor OFF / understripe OFF' cmd = &b00001100:goto command_to_lcd #display_on_1 'lcd display ON and' #lcd_cursor_1 'cursor BLINKS / understripe BLINKS' cmd = &b00001101:goto command_to_lcd #display_on_2 'lcd display ON and' #lcd_cursor_2 'cursor OFF / understripe ON' cmd = &b00001110:goto command_to_lcd #display_on_3 'lcd display ON and' #lcd_cursor_3 'cursor BLINKS / understripe ON' cmd = &b00001111:goto command_to_lcd #lcd_cursor_shift_left 'shifts cursor left without clearing character' cmd = &b00010000:goto command_to_lcd #lcd_cursor_shift_right 'shifts cursor right without clearing character' cmd = &b00010100:goto command_to_lcd #entry_mode_set_left_to_right 'sets printing to left to right ex. HELLO' cmd = &b00000110 goto command_to_lcd #entry_mode_set_right_to_left 'sets printing to right to left (backwards) ex. OLLEH' cmd = &b00000100 goto command_to_lcd '*************************************************************************************************************************' #command_to_lcd gosub busy_flag_check_from_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 0:en = 0 'setup for transmitting command to lcd display' data = &b00000000 or cmd shr 4:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'HIGH NIBBLE command to lcd' data = &b00000000 or (cmd - (cmd shr 4 shl 4)):db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE command to lcd' return '*************************************************************************************************************************' #data_to_DD_ram_lcd cmd = &b10000000 or adr : gosub command_to_lcd goto put_data_into_lcd #data_to_CG_ram_lcd cmd = &b01000000 or adr : gosub command_to_lcd #put_data_into_lcd gosub busy_flag_check_from_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 1:en = 0 'setup for transmitting data to lcd display' data = &b00000000 or dat shr 4:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'HIGH NIBBLE data to lcd' data = &b00000000 or (dat - (dat shr 4 shl 4)):db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en 'LOW NIBBLE data to lcd' return '*************************************************************************************************************************' #data_from_DD_ram_lcd cmd = &b10000000 or adr : gosub command_to_lcd goto get_data_from_lcd #data_from_CG_ram_lcd cmd = &b01000000 or adr : gosub command_to_lcd #get_data_from_lcd deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs =1 : en = 1 'setup for reading data' bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:data = data shl 4 'HIGH NIBBLE data from lcd' pulse en:bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:en = 0 'LOW NIBBLE data from lcd' dat = data goto command_to_lcd '*************************************************************************************************************************' #busy_flag_check_from_lcd deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs = 0:en = 1 'setup for reading busy flag' bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:data = data shl 4 'HIGH NIBBLE data from lcd' pulse en:bit4 = db7:bit3 = db6:bit2 = db5:bit1 = db4:en = 0 'LOW NIBBLE data from lcd' if bit8 <> 0 then goto busy_flag_check_from_lcd 'bit 8 of data is the busy flag bit / 1 = lcd is busy / 0 = lcd is ready' return '*************************************************************************************************************************' #initialize_lcd print"#ON_LCD#";:print"#INIT#";:print"#CLR#"; 'initialize lcd display' #character_build 'generates characters in lcd ram from characterbuild table / 8 characters of 5X8 pixels' for loop = 0 to 63 adr = loop 'lcd display character generation (CG) address' looktab characterbuild, loop, dat 'lcd data for character generation' gosub data_to_CG_ram_lcd 'set character generation data in CG address' next print"#OFF#"; return '*************************************************************************************************************************' ' (CG dat adr) 000/XXXXX first 3 bits are not used/ last 5 bits are for character generation ' table characterbuild &b00010001 '(0) 000/1 1' character build data for antenna symbol/ read from DD-ram address &h08' &b00011111 '(1) 000/11111' *put&h08*' &b00010101 '(2) 000/1 1 1' &b00000100 '(3) 000/ 1 ' &b00000100 '(4) 000/ 1 ' &b00000100 '(5) 000/ 1 ' &b00000100 '(6) 000/ 1 ' &b00000000 '(7) 000/ '-----------------------------------------' &b00000000 '(8) 000/ ' character build data for heart/ read from DD-ram address &h09' &b00000000 '(9) 000/ ' *put&h09*' &b00001010 '(10) 000/ 1 1 ' &b00011111 '(11) 000/11111' &b00001110 '(12) 000/ 111 ' &b00000100 '(13) 000/ 1 ' &b00000000 '(14) 000/ ' &b00000000 '(15) 000/ '-----------------------------------------' &b00000000 '(16) 000/ ' character build data for happy/ read from DD-ram address &h0a' &b00000000 '(17) 000/ ' *put&h0a*' &b00001010 '(18) 000/ 1 1 ' &b00000000 '(19) 000/ ' &b00000100 '(20) 000/ 1 ' &b00010001 '(21) 000/1 1' &b00001110 '(22) 000/ 111 ' &b00000000 '(23) 000/ '-----------------------------------------' &b00011111 '(24) 000/11111 character build data for window/ read from DD-ram address &h0b' &b00010101 '(25) 000/1 1 1' *put&h0b*' &b00010101 '(26) 000/1 1 1' &b00011111 '(27) 000/11111' &b00010101 '(28) 000/1 1 1' &b00010101 '(29) 000/1 1 1' &b00011111 '(30) 000/11111' &b00011111 '(31) 000/11111'-----------------------------------------' &b00000000 '(32) 000/00000 empty place for character build data/ read from DD-ram address &h0c' &b00000000 '(33) 000/00000' *put&h0c*' &b00000000 '(34) 000/00000' &b00000000 '(35) 000/00000' &b00000000 '(36) 000/00000' &b00000000 '(37) 000/00000' &b00000000 '(38) 000/00000' &b00000000 '(39) 000/00000 -----------------------------------------' &b00000000 '(40) 000/00000 empty place for character build data/ read from DD-ram address &h0d' &b00000000 '(41) 000/00000' *put&h0d*' &b00000000 '(42) 000/00000' &b00000000 '(43) 000/00000' &b00000000 '(44) 000/00000' &b00000000 '(45) 000/00000' &b00000000 '(46) 000/00000' &b00000000 '(47) 000/00000 -----------------------------------------' &b00000000 '(48) 000/00000 empty place for character build data/ read from DD-ram address &h0e' &b00000000 '(49) 000/00000' *put&h0e*' &b00000000 '(50) 000/00000' &b00000000 '(51) 000/00000' &b00000000 '(52) 000/00000' &b00000000 '(53) 000/00000' &b00000000 '(54) 000/00000' &b00000000 '(55) 000/00000 -----------------------------------------' &b00000000 '(56) 000/00000 empty place for character build data/ read from DD-ram address &h0f' &b00000000 '(57) 000/00000' *put&h0f* &b00000000 '(58) 000/00000' &b00000000 '(59) 000/00000' &b00000000 '(60) 000/00000' &b00000000 '(61) 000/00000' &b00000000 '(62) 000/00000' &b00000000 '(63) 000/00000 -----------------------------------------' tabend |
