 User Interface for CC1M2.01 Kategorie: C-Control I V1.2/2.0 (von Windt H.J. - 14.10.2004 8:58)
'          *                                      WINDT SYSTEMS                                            *'
'          *                 INPUT BUG WORKAROUND v1.21 for the C-Control 1 Unit M2.01                     *'
'          *                                        H.J. WINDT                                             *'
'          *                                          2004                                                 *'
'This program works around the input bug of the CC1 U M2.01.'
'Via a terminal program variables can be entered in 4 different codes -- decimal, binary, hex and ascii.'
'Download the RS232 TERMINAL at www.b-kainka.de/pcmessfaq.htm'
'Decimal, type in the positive or negative number and press enter, exam. 1234 or -1234 .'
'Binary, type &b or &B and then the binary code and press enter, exam. &b1010101010101010 or &B1010101010101010 .'
'Hex, type &h or &H and then the hex code and press enter, exam &hffff or &HFFFF .'
'Ascii, type &a or &A and then the letter, number or symbol, exam. &ah or &Ah, gives the ascii code for h.'
'There is no difference for upper and lower case letters for hex codes, exam. &hF = dec 15 and &hf = dec 15.'
' works on all inputs except for ascii, ascii will enter the code for '
'Feel free to use and share this software in any way you want!'
'****************************************************** VARIABLES ********************************************************'
define data word[1]
define number word[2]
define digit byte[5]
#start
print" Enter Number"
gosub input_number_via_232
print"number recieved ="
print number
goto start
#input_number_via_232
number = 0
digit = 0
get data                                             'get 8 bit ascii code'
if data = 8 then goto input_number_via_232           'look for ascii code for '
if data = 13 then return                             'look for ascii code for '
if data = 38 then goto check_for_hex_or_bin_or_ascii 'look for ascii code for <&>'
if data = 45 then goto input_negative_dec            'look for ascii code for <->'
#input_positive_dec
digit = digit + 1
data = data - 48        'translate ascii code into decimal'
if number <> 0 then number = number * 10 + data else number = data                                           'build number'
#input_positive_backspace_loop
if data = 8 then number = number / 10                           'debuild nuumber if ascii code for is recieved'
if data = 8 then digit = digit - 1
if digit = 0 then goto input_number_via_232                                       'go back if no more digits are displayed'
if data = 8 then goto input_positive_backspace_loop
goto input_positive_dec
#input_negative_dec
digit = digit + 1
#input_negative_backspace_loop
if digit = 0 then goto input_number_via_232                                         'go back if <-> is no longer displayed'
if data = 8 then goto input_negative_backspace_loop
if data = 13 then number = number * -1                     'look for ascii code for and make number negative if so'
#check_for_hex_or_bin_or_ascii
digit = digit + 1
#check_for_hex_or_bin_or_ascii_loop
if digit = 0 then goto input_number_via_232              'go back if <&> is no longer displayed'
if data = 8 then goto check_for_hex_or_bin_or_ascii_loop
if data = 98 then goto input_binary                      'look for ascii code for '
if data = 66 then goto input_binary                      'look for ascii code for '
if data = 104 then goto input_hex                        'look for ascii code for '
if data = 72 then goto input_hex                         'look for ascii code for '
if data = 97 then goto input_ascii                       'look for ascii code for '
if data = 65 then goto input_ascii                       'look for ascii code for
number = 0                                               'if wrong letter is pressed then number = 0'
get data                                                 'wait for key to be pressed'
return
#input_binary
digit = digit + 1
#input_binary_loop
if data = 8 then number = number shr 1                           'debuild number if ascii code for is recieved'
if data = 8 then digit = digit -1
if digit = 1 then goto check_for_hex_or_bin_or_ascii_loop                    'go back if or is no longer displayed'
if data = 8 then goto input_binary_loop
if number <> 0 then number = number shl 1 or (data and 1) else number = (data and 1)                         'build number'
goto input_binary
#input_hex
digit = digit + 1
#input_hex_loop
if data = 8 then number = number shr 4                           'debuild number if ascii code for is recieved'
if data = 8 then goto input_hex_loop
if data > 70 then data = data - 87 else if data > 57 then data = data - 55 else data = data - 48 'translate ascii code into decimal'
if number <> 0 then number = number shl 4 or data else number = data                             'build number'
goto input_hex
#input_ascii
get number                 'get 8 bit ascii code/ build number'
return
Re: User Interface for CC1M2.01 (von Windt H.J. - 22.10.2004 1:51)
