> Hallo, > > > > Hallo, (ich bin hollander, so veruntschuldige mein Deuts) > Macht nichts, kannst du mir dein Problem nochmal auf englisch beschreiben (auch per Mail)? > Ich weiß zwar etwa was du meinst, aber nur etwa! > > Cu Rene, > alias Topmail > Hello Rene, are you using a c-control 1 or a c-control 2 the cc2 is 25 times faster than cc1 a much faster possibility would be using an Atmel AVR MCU there is an IDE with wich you can Programm in Basic it's called BASCOM AVRs have a risc architecture and are VERY fast you can even buildt MP3-Player with them did i understand right your programm is waiting for 100ms-Pulses signaling "no read" from the scanner ? and after a specific time a cylinder must kick off the packet from the transportion-rubber ? what is the minimum time between two signals "no read" from the scanner ? maybe one possability would be that the signal "no read" starts an interrupt but i need more information about the times 140/pm means 140 packets per meter = 7,14mm / Packet? Speed 40m/min = 667 mm/sec? means every (667 mm/sec) / (7,14 mm/Packet) = 93,3Packets/Sec ?? or otherwise 1/93,3 = 10,7 milliseconds/Packet ? i think some of my suggestions are wrong so how is it right please post numbers with easy to understand units like Meter / Minute packets / Meter etc. sl |
