Hallo Dieter Anbei mal ein altes Demoprogramm von mir. Ich hoffe es hilft. Wenn Du noch die alte CControl 1.1 nutzt dann schau doch mal in den Downloadbereich der CControl(nicht Open Mikro), da gibt es noch eine einfachere Lösung zur Ausgabe von Variablen und Zählerständen. Du benötigst dann allerdings ein Schieberegister vor der LCD-Anzeige. 'ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ» 'º C-CONTROL BASIC-PROGRAMM º 'º BIN_LCD3.BAS º 'º LIESST EINEN WERT AN AD1 EIN, WANDELT DIESEN º 'º UND GIBT DIE ASCII-FOLGE AUF EINEN LCD-DISPLAY AUS. º 'º DEMOVERSION IN REAL-TIME º 'ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ DEFINE POTI AD[1] 'WERT VOM AD-EINGANG 1 LESEN DEFINE ZAHL WORD 'ENTHAELT DIE BINAERZAHL DEFINE MERKER WORD 'ENTHAELT DAS ZWISCHENERGEBNISS DEFINE MENGE WORD 'ENTHAELT DIE ZU SUBTRAHIERENDE ZAHL DEFINE REST BYTE 'ENTHAELT DEN MODULO-WERT DEFINE TAUSEND BYTE 'ENTHAELT DEN ASCII-CODE DER TAUSENDERSTELLE DEFINE HUNDERT BYTE 'ENTHAELT DEN ASCII-CODE DER HUNDETERSTELLE DEFINE ZEHNER BYTE 'ENTHAELT DEN ASCII-CODE DER ZEHNERSTELLE DEFINE EINER BYTE 'ENTHAELT DEN ASCII-CODE DER EINERSTELLE DEFINE I BYTE 'ZAEHLER FUER DIE SCHLEIFE 'ÍÍÍÍÍÍÍÍÍÍ VARIABELN FUER DAS LCD-DISPLAY ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ DEFINE DATA BYTEPORT[1] 'ENTHAELT DAS ZU SENDENDE ASCII-ZEICHEN DEFINE RS PORT[11] 'L=BEFEHLSEINGABE / H=DATENEINGABE DEFINE RW PORT[10] 'L=DATEN SCHREIBEN / H=DATEN LESEN DEFINE E PORT[9] 'ENABLE EINGANG ZUR DATENUEBERNAHME 'ÍÍÍÍÍÍÍÍÍÍ DISPLAY KONFIGURIEREN ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ RS=0:RW=0:DATA=&H38 'DISPLAY 2-ZEILIG / 5X7 DOT PULSE E 'DATEN UEBERNEHMEN RS=0:RW=0:DATA=&H0C 'DISPLAY EIN/CURSOR EIN/BLINKEN AUS PULSE E 'DATEN UEBERNEHMEN RS=0:RW=0:DATA=&H01 'DISPLAY LOESCHEN UND CURSOR IN GRUNDSTELLUNG PULSE E 'DATEN UEBERNEHMEN #LOOP 'ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ» 'º AD-WERT INTERPOLIEREN º 'ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ I = 0 'ZAEHLER RESETTEN FOR I = 0 TO 119 'MAX 128, DA 255x128,5 = 32768 ZAHL = ZAHL+POTI 'MESSWERTE ADDIEREN NEXT I 'WEITERZAEHLEN ZAHL = ZAHL/120 'MITTELWERT AUSRECHEN 'ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ» 'º CODE-WANDLER º 'ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ IF ZAHL > 9999 THEN ZAHL = 9999 IF ZAHL <= 0 THEN ZAHL = 0 'ÍÍÍÍÍÍÍÍÍÍ TAUSENDER STELLE ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ REST = ZAHL MOD 1000 MERKER = ZAHL-REST MENGE = MERKER/1000 TAUSEND = MENGE+&h30 MENGE = MENGE*1000 ZAHL = ZAHL-MENGE 'ÍÍÍÍÍÍÍÍÍÍ HUNDERTER STELLE ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ REST = ZAHL MOD 100 MERKER = ZAHL-REST MENGE = MERKER/100 HUNDERT = MENGE+&h30 MENGE = MENGE*100 ZAHL = ZAHL-MENGE 'ÍÍÍÍÍÍÍÍÍÍ ZEHNER STELLE ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ REST = ZAHL MOD 10 MERKER = ZAHL-REST MENGE = MERKER/10 ZEHNER = MENGE+&h30 MENGE = MENGE*10 ZAHL = ZAHL-MENGE 'ÍÍÍÍÍÍÍÍÍÍ EINER STELLE ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ EINER =REST+&H30 'ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ» 'º LCD-DISPLAY º 'ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ 'ÍÍÍÍÍÍÍÍÍÍ FUEHRENDE NULLEN UNTERDRUECKEN ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ IF TAUSEND = 48 THEN TAUSEND = 32 IF TAUSEND <> 32 THEN GOTO WEITER IF HUNDERT = 48 THEN HUNDERT = 32 IF HUNDERT <> 32 THEN GOTO WEITER IF ZEHNER = 48 THEN ZEHNER = 32 #WEITER 'ÍÍÍÍÍÍÍÍÍÍ GRUNDSTELLUNG LCD DISPLAY ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ RS=0:RW=0:DATA=&H02 'CURSOR UND TEXT IN GRUNDSTELLUNG PULSE E 'DATEN UEBERNEHMEN RS=1:RW=0 'START DER ASCII-UEBERTRAGUNG 'ÍÍÍÍÍÍÍÍÍÍ ZEICHEN-NR.1 ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ DATA=TAUSEND PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ ZEICHEN-NR.2 ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ DATA=HUNDERT PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ ZEICHEN-NR.3 ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ DATA=ZEHNER PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ ZEICHEN-NR.4 ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ DATA=EINER PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ TEXT AUSGEBEN ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ RS=0:RW=0:DATA=&H85 'CURSOR POSITIONIEREN PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ TEXT UEBERTRAGEN ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ RS=1:RW=0 'START DER ASCII-UEBERTRAGUNG DATA=&H49 'ZEICHEN "I" PULSE E 'DATEN UEBERNEHMEN DATA=&H73 'ZEICHEN "s" PULSE E 'DATEN UEBERNEHMEN DATA=&H74 'ZEICHEN "t" PULSE E 'DATEN UEBERNEHMEN 'ÍÍÍÍÍÍÍÍÍÍ PROGRAMM BEENDEN ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ GOTO LOOP END |
