Dürfte funktionieren, oder? OPTION CC2.0 const EIN = off const AUS = on '3 x Taster für 1 x Jalosie define Taster_Auf1 as Port[1] define Taster_Ab1 as Port[2] define Taster_Auf2 as Port[3] define Taster_Ab2 as Port[4] define Taster_Auf3 as Port[5] define Taster_Ab3 as Port[6] '2 x Relais für Jalosie define Ext_Rel_Auf as Port[7] define Ext_Rel_Ab as Port[8] define SDA as port[9] SDA=on define SCL as port[10] SCL=on #PrgLoop 'Schaltet Jalosie Auf IF Taster_Auf1=EIN or Taster_Auf2=EIN or Taster_Auf3=EIN then Ext_Rel_Auf=EIN End IF 'Schaltet Jalosie Auf IF Taster_Ab1=EIN or Taster_Ab2=EIN or Taster_Ab3=EIN then Ext_Rel_Ab=EIN End IF GOTO PrgLoop |
